Cat 12 Door/window Gasket Material
WARBIRDF4
Send a private message to WARBIRDF4
Hi Folks I Am In The Process Of Putting In New Glass On My # 12 Motor Grader Any Idea What I Should Use For The Rubber Gaskets That Holds The Glass In Or Where I Could Buy Some.... Also I Would Like To Get Some New Door Latches Thanks Mark
Sat, Jan 5, 2008 10:01 AM
CAT or you local glass supplier probably can supply some along with the glass.
Sat, Jan 5, 2008 9:11 PM
| Kingaroy, Queensland
