Cat 12 9K Grader U Joints for PTO Shaft
Showing 1 to 10 of 19 results
hvygambler
Send a private message to hvygambler
Hello, first time posting and looking to help a friend without a computer
Have a 1942-43 Cat 12 9K5000 or so Grader and the PTO Shaft for the controls has wiped out U Joints, I take it these are non standard size PTO Shaft sized joints as I can not find anything wide enough with small enough caps. I was a truck mechanic and made shafts for road tractors over 20 years ago and have nothing close to these. I have ordered a parts manual but trying to get this up as soon as possible for a spring road repair after the snow.
Does anybody have a Parts Manual handy where they could look up the part number for the 2 U Joints please.?
The caps are about 13/16" .. on 1 joint the caps were brass and piened in but the other had internal snap rings 2 1/16" on the ring od width and 3 1/16" outside width of the joint
My friend tried Cat and they gave him the wacked out eyeball twisting in head look, although he did get parts about 12 years ago and the parts listing was on microfiche then but the dealer did not even have the system any longer, however they had dropped 25k on undercarriage work on a dozer so they probably didn't mind spending some time
Any help would be appreciated and read some neat info I forwarded on to him as he though was a 1949 but it has to be before 45 for sure. Interesting to have read in the operators manual where to place TNT to blow the machine up if needed back during WW2
Again thanks for taking the time to read and help if you can
Wed, Apr 9, 2014 11:31 PM
Thank you received: 50
Must be an odd ball for sure. No aftermarket interchange listed for 9K1-up or for 7T1-3099. Most all the other 12's and 14's use the same u-joint.
Thu, Apr 10, 2014 12:33 AM
daron
From Pg. #143 of 9K1-9K2000 Pts. Book:
2- CROSS & BEARING ASSEM. 6F9741
This for Drive Shaft Assemblies 7F2617 (replaces 5B43😎 and 8F3786 (replaces 7F2617)
Daron
Thu, Apr 10, 2014 1:58 AM
Reply to daron:
Daron
Might be a few of them out there....
http://www.machinerytrader.com/list/partssearch.aspx?partnum=6F9741
Thu, Apr 10, 2014 2:05 AM
hvygambler
Thank you to all very much, I just talked to my pal and he said he went to a different company Cat dealer today and they had the Microfishe viewer still and showed the joint, washers and caps separate but the caps not available but sold him 2 6F9740 cross's and the washers but didn't know if cross was complete with caps, well I bet they won't be and you guys have the correct number. They overnighted them so he will see tomorra..
I truly appreciate all the help and the prompt replies, I did not look until just now but wow you guys are tops for helping on this old metal
Thu, Apr 10, 2014 7:15 AM
Reply to hvygambler:
6F9740 is for cross only
Requires (😎
Bearing 6F9739
Lock ring 6F9738
Washer 6F9737 (steel)
Washer 5B0426 (cork)
Thu, Apr 10, 2014 7:47 AM
Thank you received: 34
Hi hg,
it is possible those joints are Blood Brothers in origin.
I note you have drive line experience, so if you have no luck chasing down the correct parts and seeing as the drive has 4 bolt flanges at each it would be possible to make or purchase adaptor flange plates to adapt in later available pattern joints. Have done this on vintage trucks etc. in the past.
At The Dealer we had a range of adaptors to adapt drives to transmissions, hyd. pumps etc. on our Wolff Hydraulic Test Centre as well as some for our Taylor Engine Dynamometer.
Thu, Apr 10, 2014 7:52 AM
Reply to edb:
Hi hg,
I don't have the parts book to check it out but it may be possible to change out the entire flange to flange drive shaft with a later, more common unit.
Thu, Apr 10, 2014 8:19 AM
STEPHEN
I had the same problem on a 212 grader, the original caps were brass and turned directly on the cross without needle bearings. I solved it by swapping in a 212 shaft from a year or so later unit that used used the "mechanics" style joint. I got the joint at NAPA, you might be able to try something similar.
Thu, Apr 10, 2014 9:13 AM
Reply to STEPHEN:
I don't have the #12 9K parts book but here is a #112 3U that uses the same odd ball joint.
I can provide grader models that use the later common U-joint if desired.
Thu, Apr 10, 2014 9:53 AM
Soapy
Send a private message to Soapy
Many years back, when I worked at a real auto parts store/machine shop, Spicer supplied us with a catalogue that I would love to possess again.
It had every u-joint listed that was ever made, companion flanges, and you could even order new driveline tubing from them.
Many times guys would come in, looking for parts to build a driveline for a truck, or even antique watercraft, and I spent many hours pouring through the book to get all the right parts ordered.
Thu, Apr 10, 2014 10:46 AM
