cat 12
hannahp
Send a private message to hannahp
I have 2 CAT12 graders built in Australia 1955- serial numbers 94C 92 and 94C 97
My CAT12 parts book quote part numbers for 8T serial number ranges
Can't determine which 8T serial number ranges correspond to my Australian built serial numbers to be sure to order correct parts
Can anyone help cross reference aussie sn with the american sn
Tue, Jan 13, 2026 11:50 PM
Mark Riendeau
Thank you received: 23
Just buy a couple parts books for your machines.
Wed, Jan 14, 2026 10:56 PM
Thank you received: 54
From a thread entitled "", this is mentioned:
"94C0066 is equivalent to 8T15759,"
and
"The 94C is the same as the US 8T models. #66 would be an early model with the small pre-com chamber diameter head. Early D318 engines would have the raised boss for DE starter mounting, later models had the pre-drilled DE starter provision."
so your grader would want the parts catalog at least as late as that 8T number. If the next form was close in number, it could pay to get the following form as well. There's this reproduction which includes the operator's handbook and the serviceman's reference https://www.ebay.com/itm/185788218131?_skw=caterpillar+12+grader+manual&itmmeta=01KEZQ4AQZV9ARQRSEFAPTCKAA&hash=item2b41d73b13:g:o9AAAOSwW19nDAdS&itmprp=enc%3AAQALAAABAO7PUuNWmJ%2B%2BUShgI9tQz%2Fqa5wjI1lWOh7TrqYnd8qHK13mXBubTBfRMuSbuW3GXDrp00kzO6EyVabdg7UrNm2%2B%2Fv95yQx0FzmbxCzrIphIlwPN1YjVAJF%2B2yRzqbi%2FwUJNhwu%2BNFUK0PAZokBuo9tSgxt%2BlKjb1d%2FN0VpX2nDu8tnnmIsQAm%2BcemoQ%2BcFCusgr4zhaiN69Vk3HrQjJI7ac172Jlw1cF7ZvZxFdoKtzyLcERhnYPMobhOzKNgAbbC%2BKTVU8PLytNjZtcnW8iPUgROGOYJPPVvTNQ2RSGH1uAhI9aBr9qryfikU8p3B1Q2QAiFzQnwqo1Y%2Bn4lAzuSwM%3D%7Ctkp%3ABFBMkqyR9_dm
Thu, Jan 15, 2026 2:20 AM
