Cat 112 pony no fire
westfork
Send a private message to westfork
Parked the grader last fall, went to fire it, no spark from the mag. I’ve buffed the points new plugs. Going to gap the points tomorrow. If that doesn’t work is my next option to pull the mag? It’s in such fun place to work on too. The machine sat for 3 years and a little buff on the points and she fired right off , been working fine till now.
Any one in the Eugene OR that has some expertise I sure could use the help.
Don G.
Tue, Jul 7, 2020 10:22 AM
Try disconnecting the kill switch.
FILE the points
Check or replace the condenser
Mag could be wet inside and drying it out in an oven could fix it.
Tue, Jul 7, 2020 10:31 AM
westfork
FILE the points
[quote="ccjersey"]Try disconnecting the kill switch.
FILE the points
Mag could be wet inside and drying it out in an oven could fix it.[/quote]
Well tried all of the above, except the condenser. Still no fire. So looks like I will have to pull the mag. There is almost impossible to work on in place. Appears the carb has a stuck float too so time to go a little deeper. Thanks for the reply.
Don G.
Fri, Jul 10, 2020 10:19 AM
| Kingaroy, Queensland
