Cat 112 grader serial number
Showing 1 to 10 of 19 results
DGriffin
Send a private message to DGriffin
Gday Im a new member I’ve just purchased a tied old 112 grader I want to breath some life into the old girl I can’t find any id plates or serial numbers on both the machine or engine can anyone point me in the rite direction
cheers Dale
Sun, Mar 9, 2025 7:19 AM
Thank you received: 131
Hi, DGriffin.
Ifn my mem'ry serves me rightly, there should had oughta be a serial # plate or the place where one 'yoosta' be on the engine block inboard of the starter pinon clutch lever and another on one side or the other - but usually the left - of the forward sloping section of the gooseneck. If the tags are gone, look for traces of old rivets or rivet holes 'cos the SN should be stamped into the parent metal under where the tag yoosta was.
Sun, Mar 9, 2025 11:52 AM
DGriffin
Hi, DGriffin.
Ok thanks deas plant I’ll have a look if it is stamped in the main frame or the block
Sun, Mar 9, 2025 1:13 PM
cr
Send a private message to cr
Thank you received: 25
 Look here, the other spot is on the flange between the block and oil pan, sometimes it’s under the injection pump other times it was over by the oil filter.
Sun, Mar 9, 2025 10:35 PM
Thank you received: 60
Reply to cr:
Mon, Mar 10, 2025 2:36 AM
DGriffin
Got the engine serial number S9T56 not sure if it is a 311 or a 315 no luck with the machine s/no I can see where the old rivot holes are on the left front side of the goose neck but no numbers stamped into frame I should be fine once I work out which engine I have I need to order parts for engine I can’t get it to fire I have fuel up to injectors still no go I am thinking low compression since the oil bath air filter was empty I am trying to work out how to do a compression test on it as in what adaptors I need what’s your thoughts
Cheers
Mon, Mar 10, 2025 2:16 PM
Reply to DGriffin:
Cheers
Hi, DGriffin.
If this machine has been standing for a while but the engine is still turning free, remove the injectors and put a 'squirt' of engine oil into each cylinder. Let it soak for a 1/2 hour or so and then turn the engine over a few times to spread the oil around the rings and up and down the cylinder walls. Replace the injectors and try again to start it.
If the engine is 'tired', the oil might just be enough to get the compression up to a level at which it will start and run. NOT a permanent fix but it may get you going.
Mon, Mar 10, 2025 3:15 PM
DGriffin
Hi, DGriffin.
Ok Will do
Thanks deas
Mon, Mar 10, 2025 3:45 PM
Reply to DGriffin:
Ok Will do
Thanks deas
Hi, DGriffin.
Happy oiling.
Mon, Mar 10, 2025 3:58 PM
bruce oz
Thank you received: 23
 S9T56 is a Australian built Steelweld grader
Tue, Mar 11, 2025 2:18 AM
DGriffin
Reply to DGriffin:
Cheers
Gday I put some oil in the cylinders and started it briefly I think I’m up for at least a hone and some new rings but I will probably open up a can of worms
Have you got any idea which engine it is with engine s/no -S9T56 or can you tell by photos and would you have any recommendations on engine parts suppliers for these old girls
Cheers dale
Tue, Mar 11, 2025 2:16 PM
