cat 10 wiring
cat 10 wiring
Phrank
Send a private message to Phrank
I finally am putting my cat 10 back together. But I forgot how the wiring goes from the magneto to the switch. How does it then get hooked to ground? Can any one help? Thanx
Wed, Apr 9, 2008 11:23 PM
chugwater crawlers
My PV-15 should be the same as your ten. Switch grounds out at the firewall with a single wire to the magneto.
Thu, Apr 10, 2008 5:38 AM
tomseabee
Send a private message to tomseabee
Reply to chugwater crawlers:
My Cat Ten has single wire to the mag and the switch directly grounds it without any additional wire.
Gud luck,
tom
Thu, Apr 10, 2008 6:56 PM
