Cat 10 steering clutches
artreed
Send a private message to artreed
Hello All,
Can someone tell me the maximum(new) thickness and minimum (worn out) thickness of the steering clutch pack on the Cat10's I have 2.25" on one side and 2.16" on the other.
I am into them this far and have to replace the release bearing on one side. Just want to see where i am at as far as wear. Even when this machine is restored i don't see it getting that many more hours of use.
Thanks,
Art
Mon, Jun 3, 2019 8:51 AM
Thank you received: 93
scan should get you there for early machines.
Mon, Jun 3, 2019 10:51 AM
artreed
Reply to edb:
Thank you Ed. That's great. At 2.25" I have an almost new clutch on the one side. Best news I've found on this tractor so far.
Art
Mon, Jun 3, 2019 7:41 PM
MARCOTEN
Reply to artreed:
Art
that you have a minimum of wear you can probablu see also on the brake pedals, probably the square blocks are very intaks and not worn off.
Tue, Jun 4, 2019 5:13 AM
Reply to MARCOTEN:
It probably spent most of its life as an Ag Tractor going in one direction around a field hence more wear on one side.
If it bugs you, just swap them left to right, then you can keep going around the "field" in the same direction! 😆👋
Tue, Jun 4, 2019 6:21 PM
