Cat 10 oil seal
Cat 10 oil seal
catmandan
Send a private message to catmandan
We just rebuilt a cat 10. When turning it over with a drill we get 25 lbs. of oil pressure & it leaks oil out the back bearing into the clutch (there is no oil seal). What can we do to stop this leak.
Tue, Jan 7, 2014 12:55 AM
hiwide15
Send a private message to hiwide15
If you turned the crankshaft down you need to have the reverse thread also turned deeper into the crankshaft to return oil to the drain hole in rearmain bearing. Need to make sure the passage way is clear also. Got more questions call me 716-753-0056 Ron Meeder
Tue, Jan 7, 2014 1:24 AM
tailseat15
Send a private message to tailseat15
Reply to hiwide15:
What are you turning over, the crank or just the oil pump? If the crank isn't turning, the threaded groove won't be doing its job.
Tue, Jan 7, 2014 11:55 AM
catmandan
Reply to tailseat15:
[QUOTE=tailseat15;119965]What are you turning over, the crank or just the oil pump? If the crank isn't turning, the threaded groove won't be doing its job.[/QUOTE
Thanks for the reply. We are turning the crank with a 3/4 in. drill.
Tue, Jan 7, 2014 11:15 PM
