Cat 10 Missing when hot
archdf
Send a private message to archdf
I was using my Ten the other day pulling some logs, and after I worked it for a while it started missing under load. It has done this on several occasions. Anyone have any ideas on where to start looking.
Tue, May 26, 2009 11:05 PM
jmvmopar
I'd suspect it to be an ignition problem, bad plug, wire, or weak mag.
Tue, May 26, 2009 11:36 PM
When have you checked your valve clearances?
I second the mag/wire/plug suggestion, I think that is more likely than the valves, but not a bad idea to check your clearances anyway.
Wed, May 27, 2009 1:06 AM
hicrop10
Archdf,Would you like to add your 10 to the registry that I'm making up for the 10's that still exist.If so email,PM,or call me with the serial #,location, condition.Thanks Mike Durkin
Wed, May 27, 2009 2:16 AM
Dunefanatic
Send a private message to Dunefanatic
Reply to hicrop10:
Might ask if your fuel tank is vented or cap has a vent hole. This was a design flaw in the Ten where on later tractors they vented the Ten tank so when the tractor got warm and the fuel got hotter you would not get a vapor/vacume lock. You could be running low on fuel when hot and under a load.
Wed, May 27, 2009 2:25 AM
archdf
Reply to Dunefanatic:
Thanks for the input, I will check these out and see if this is my problem.
Thu, May 28, 2009 1:02 AM
