Cat 10 engine block
Cat 10 engine block
After getting the lower radiator tank repaired,we started the engine and the coolant began blowing out of the radiator as the engine warmed up. A crack is visible on the left side of cylinder #1 (external), and there must be crack(s) from the cylinders into the water jacket.
Is there any chance of finding a replacement block? The head was salvaged from another 10, checked and surfaced before installation.
Thanks,
Tom S
Wed, Mar 4, 2026 4:22 AM
catrjw
Send a private message to catrjw
I have a used block in western PA from a parts tractor. 412-721-2058 Rick
Thu, Mar 5, 2026 2:53 PM
