cat 10 clutch rehab
cat 10 clutch rehab
artreed
Send a private message to artreed
Hello everyone. I am currently rehabilitating a cat 10. getting the motor running was the easy part. the throwout bearing in the clutch mechanism had disintegrated. nothing left but a couple ball bearings on he floor of the bell housing and the tangled remnants of the cage.
Sasquatch's youtube video of the throwout bearing replacement has been very helpful. I have sourced most all the parts I need except the pilot bearing in the flywheel. It too was pretty crusty. My local bearing distributor was not able to find a suitable replacement. An oil bronze bushing has been suggested by the bearing salesman as well as my local machinist. Has anyone here either found a bearing or tried the oil bronze bushing idea?
thanks very much.
Art
Sat, Aug 25, 2018 9:07 AM
Steve A
I would be fine with the bushing, it is only in motion when the clutch is open, should last a long time in a hobby machine.
Sat, Aug 25, 2018 9:11 AM
josh
Thank you received: 14
Reply to Steve A:
The pilot bearing assembly in the flywheel, 1B3755 consists of a 1B3757 and the roller assembly 1B3756 which was used in the steering clutch of some later tractors and could be available.
The Hyatt numbers for the parts are:
1B3755, Hyatt #17059
1B3757, " #31262
1B3756 " #00531
And an old thread on the subject: http://www.acmoc.org/bb/archive/index.php/t-17223.html
https://aftermarket.supply/caterpillar/1b3756.html
Sat, Aug 25, 2018 1:14 PM
artreed
Reply to josh:
1B3757, " #31262
1B3756 " #00531
Hi Steve,
I hadn't thought about that, the bearing is only active when the clutch is depressed. this tractor will never see the hard use it has had in it's younger days
Josh, thanks for those numbers The number on the outer race jives but the Hyatt number on my bearing is 7788. I'll go back to the bearing distributor with this new number and see where it leads
Thanks for the help.
Art
Sun, Aug 26, 2018 7:30 AM
hfdzl
Reply to artreed:
Hi Steve,
Art
try www.locateballbearings.com
millions of bearings usually good prices
Sun, Aug 26, 2018 4:14 PM
