Cat 10 carb
Cat 10 carb
Showing 1 to 9 of 9 results
carole walker
Send a private message to carole walker
I have had problem with ensign carb. on ten 1931 I can't get leaks to stop. Is there any carb replacement. Had the carb rebuilt but still leaks.
Thanks for any help
Gene
Thu, Dec 5, 2019 2:37 AM
hiwide 15
Send a private message to hiwide 15
Where are the leaks?, Need more information to make any recommendations
Thu, Dec 5, 2019 4:14 AM
chriscokid
Reply to hiwide 15:
you must file all flat surfaces to get the gaskets to seal properly.
Thu, Dec 5, 2019 4:45 AM
MARCOTEN
Reply to chriscokid:
Your gaskets are mabe too thin.
Use 2mm corc-neoprene for big lid gasket and for on top of pedestal inside.and find out how thick the lowest gasket ( just a o ring will do) should be, mount pedestal without any gaskets and measure how many free play pedastal has with with checking free play with screw G. That must be thickness of lowest gasket, then put the 2mm gaskets on top of pedestal and for the big lid.
Ones you know the trick its not soo difficult...
If by any reasons you want to sell your carb let me know.
A new mavel slebner carb with 90 degree elbow will do aswel.
Thu, Dec 5, 2019 5:30 AM
carole walker
Reply to MARCOTEN:
Looking in air intake past chock gas leaks in chamber. We have tried adj. on float and replacing float.
Thanks for your help.
Gene
Thu, Dec 5, 2019 10:08 PM
carole walker
Reply to MARCOTEN:
[quote="MARCOTEN"]Your gaskets are mabe too thin.
A new mavel slebner carb with 90 degree elbow will do aswel.[/quote]
Do I understand correctly a marvel slebner carb with a 90 elbow will fit?
Thu, Dec 5, 2019 10:11 PM
MARCOTEN
Reply to carole walker:
Yea. To replace the broken carb of my ten I bought a brand new carb on ebay and made an elbow and fitting oval to mount on the engine.
[attachment=56243]20191205_205312.jpg[/attachment]
Fri, Dec 6, 2019 3:03 AM
Wig
Send a private message to Wig
Reply to MARCOTEN:
[quote="MARCOTEN"]Yea. To replace the broken carb of my ten I bought a brand new carb on ebay and made an elbow and fitting oval to mount on the engine.
[/quote]
What brand of carburetor is that?
Fri, Dec 6, 2019 10:07 AM
MARCOTEN
Reply to Wig:
[/quote]
Thats a new carb non brand and an copy of marvel slebner.
Its too long ago to remember the excact seller on ebay.
Fri, Dec 6, 2019 3:47 PM
carole walker
Reply to MARCOTEN:
Thanks for help from fellow members. We had a carb shop rework carb it still had leaks We have leaks down to a drip. It seems the end guide on throttle shaft is worn. We can see a way to seal.
Thanks for all your interest and help
Gene
Sat, Dec 7, 2019 5:30 AM
| Kingaroy, Queensland
