carco hoist winch
carco hoist winch
Showing 1 to 6 of 6 results
vasco
Send a private message to vasco
I recently bought this old winch it had stood for 25yrs and was stuck it is a model G. I was told it was working well when removed .I stripped it completely and apart from the brakeband as far as im concerned its perfect it now turns freely by hand on the input shaft it is very heavy and a tribute to its makers.Please can anyone say what the capacity of the winch is I think these were fitted to some uk forestry comission D7s in the 60s
Sun, Jan 4, 2009 11:02 PM
josh
Thank you received: 13
In a catalog dated 8/47, the Model G winch used on the D7, has a line pull with a bare drum of 42,000 lbs.
Sun, Jan 4, 2009 11:22 PM
Thank you received: 60
Reply to josh:
Does it look like this???
Sorry, that's all I know about it.
There is a third picture.....might as well have the set. Yes, it is a "G" model.
Sun, Jan 4, 2009 11:32 PM
vasco
Reply to josh:
that must be its brother thanks
Mon, Jan 5, 2009 2:27 AM
vasco
Reply to josh:
thats useful information many thanks
Mon, Jan 5, 2009 2:29 AM
OzDozer
Reply to vasco:
The Carco Model G winch could be fitted to a number of makes of tractors. I do not have the Model G catalog for the D7, but I do have the Model G catalog for the A-C HD-10.
Interestingly, the HD-10 Model G line pull, with 101 PTO HP, is 39,000 lbs on a bare drum.
Also of interest, is that the main case is a one-piece casting, and was made from a patented, high strength, alloy steel that Pacific Car and Foundry called CARCOMETAL. The Carco winch also used heat-treated alloy steel gears, 4 stage gear reduction, and interchangeable standardised parts.
Tue, Jan 6, 2009 8:25 AM
vasco
Reply to OzDozer:
Now that is interesting im glad I asked this question, cast into the housing is the name pacific car & foundry. thank you
Wed, Jan 7, 2009 4:10 AM
| Kingaroy, Queensland
