Carburetor
Carburetor
jthornton
Send a private message to jthornton
I was wondering if someone knows if I can use a 5f3525 bowl that came off a 9k grader and I am trying to put it on a cast body that is on a D2 5U. It bolts up on the the tower. But I don’t know if it will provide the gas.So in other words I am trying to swap out a 5f3527 for a 5f3525 because the bowl was missing from the body.thanks
Sat, Nov 10, 2018 11:49 AM
gemdozer
Thank you received: 25
Yes the carburator bowl from 9 k should fit on d2 5u
Sun, Nov 11, 2018 2:11 AM
