Carb or Parts for D2 4U
Showing 1 to 10 of 28 results
Gregness
Okay, this is going to sound a little weird, but here goes:
Those few of you that might have been following my progress in restoring my Grandfather's D24U may recall that I have never been able to get the Pony carb to work right. I finally figured out why. The main jet that sits in the float-bowl is MISSING. I wondered every time I took it apart that the needle that is suspended from the top of the float bowl seemed to just seat into a hole in the bottom with no brass receiving jet, but what do I know? So I finally looked closely at some diagrams and there it is ( or is supposed to be). Boy am I a dumbass. I guess my Grandfather's mechanic buddy who helped him with forgot to put it back in after disassembly and cleaning(probably a dozen years ago).
In any case, I either need a parts carb or a main jet. So far I have called Florin Tractor, General Gear in Boise, the carb shop in LA that sells Zenith, and a couple of collectors I was told about, but no luck so far. The Cat part number for the carb is 5F3527, I think the Zenith number is X10368f.
BTW, I have a message in to the Carb Shop, no response yet. I bought my rebuild kit from them. I know this was the missing link in a great running pony motor, so now I feel really close but still a million miles away... any help is mightily appreciated!
Greg
Sun, Jan 19, 2014 7:16 AM
Thank you received: 57
I don't have one but funny you mention that - I often wonder how big (or little) of a deal it would be to make new jets. The stock is nothing special - brass I guess, so it'd mostly be a matter of getting the diameter and length correct I supposed. I'd like new jets but lack the means to make them and I'm not aware of anyone that makes new ones.
Sun, Jan 19, 2014 7:42 AM
ag-mike
i think i got 1 with the couple parts carbs i got. i'll let u know tomorrow.
Sun, Jan 19, 2014 7:50 AM
Machias cat
Send a private message to Machias cat
Reply to ag-mike:
Look at this page: http://www.robertscarbrepair.com/piccategory.asp?id=362
This is for a JD diesel 2 cyl starting motor but the carb (Zenith TU3X1C) is similar as used on the D2 pony.
If your part is listed, I think you can buy it at your local JD dealer or maybe from Roberts Carb repair?
I cannot vouch for the jets being exactly the same but they probably are. Maybe someone here on the board can chime in and let us know before you buy a part you cannot use.
I hope this helps...
Sun, Jan 19, 2014 9:33 AM
fordhook
Send a private message to fordhook
Reply to Machias cat:
Do you have a Caterpilliar part number? If so, check it out with Caterpillar parts, it may be available.
Sun, Jan 19, 2014 10:07 AM
Gregness
Reply to ag-mike:
Thanks Mike, I look forward to hearing what you find!
Greg
Sun, Jan 19, 2014 10:09 AM
Gregness
Reply to fordhook:
The only part number Cat provides in the catalog that came with the machine is for the whole carb, not for individual parts...
Gregness
[quote="Machias cat"]Look at this page: http://www.robertscarbrepair.com/piccategory.asp?id=362
I hope this helps...[/quote]
Boy that does look like a similar carb. If nothing else pans out I will give one of those a try.
Sun, Jan 19, 2014 10:13 AM
ol Grump
Reply to Gregness:
I've rebuilt several Cat pony carbs with gaskets and parts I got from the local John Deere dealer. The carb is used on 720-730 starting engines so have your JD parts guy get the old books out and do a bit of digging.
Sun, Jan 19, 2014 7:48 PM
Gregness
Well since my other potential sources are not panning out, I may try and buy a main jet for that JD Pony. However, I went on a JD forum and found that they talk about their Pony motors turning 7000 RPM (!), and listening to U-Tube of a 720 Diesel being started, it sounded like it! Makes me wonder how good a match the Main jet from that Zenith Carb might be...
Anybody got any insight on this?
Mon, Jan 20, 2014 3:19 AM
Reply to Gregness:
I thought the Cat carbs were actually manufactured by Zenith?? :noidea:
Mon, Jan 20, 2014 3:39 AM
