Cannot access "CAT Worldwide Model Directory 2007".
Showing 1 to 10 of 18 results
TOP
Send a private message to TOP
I am a member and it tells me I have to sign in from google.
Tue, Jun 30, 2026 9:01 PM
Thank you received: 226
Top -- ACMOC discontinued the store some time ago. ACMOC no longer sells models, decals, some parts, that were available in the past. - cts
Tue, Jun 30, 2026 9:30 PM
TOP
Reply to ctsnowfighter:
It isn't a purchase item, it is the document that shows the year of manufacture based on serial numbers. When the google doc comes up it won't let me access it.
Wed, Jul 1, 2026 3:41 AM
Thank you received: 78
Hi TOP, we'll need to address that. The forum has goggle trackers on it but not allowing those shouldn't stop a user from being able to access the content. I just tested it myself and also got the goggle message.
Wed, Jul 1, 2026 10:57 AM
TOP
Any idea when it will be fixed? That serial number to year of manufacture table would be really handy.
Thu, Jul 9, 2026 4:31 AM
wimmera farmer
Thank you received: 10
I am also having trouble cannot see library. Paid member for 10 years and on this board for longer i think. Don't think I am recognised as a member. Appreciate the help thanks WF
Thu, Jul 9, 2026 9:20 AM
Mark Riendeau
Thank you received: 34
This site has deteriorated.
Thu, Jul 9, 2026 9:51 AM
TOP, the message I get is to "allow google cookies" which presumably means I need to do just that. Are you instead getting a "login required" or similar message? Would you be able to post a screenshot of what you're getting?
Is this it?
Thu, Jul 9, 2026 12:23 PM
TOP
I also happen to be signed into my Google account when I try this.
I also found what I needed in another place. But that was a lot of work as follows:
Home -> Tech Lib Docs -> Lib Index -> Search Serial -> Click Specs -> Serial Product ID No. Index (Can't click)
But if I copy the title of the document and search in the full index I can click it and it comes up.
I also tried it from a private browser window as that removes any extensions, cookies and settings a normal browser window would have.
Thu, Jul 9, 2026 1:59 PM
Deebo
Librarian
Thank you received: 107
Reply to wimmera farmer:
You are showing as a member but with a username of Colin-Warwick-9698 Let me know if you want to consolidate your 2 accounts into one and if so which you want to keep.
Thu, Jul 9, 2026 5:13 PM
Deebo
Librarian
Looks like Google have changed a few things which will take a little while to sort out. So we think the best plan is to change the hosting of the Library data to a different place. Watch this space!!
Thu, Jul 9, 2026 5:14 PM
