Can anyone identify this blade
Showing 1 to 10 of 31 results
robert22
Send a private message to robert22
Hi
This blade is what was.on my D47U 20148
The identification tag is missing, was located right upper corner, backside of blade.?[attachment=43933]1502232624634399830520.jpg[/attachment]
Wed, Aug 9, 2017 5:52 AM
Hi Robert,
your blade was built by Caterpillar and is both an Angle and Tilt unit.
Here Down-under in Australia they were built both by Steelweld and later by Caterpillar--by editing in your approximate location can sometimes get you more accurate data.
Wed, Aug 9, 2017 6:33 AM
robert22
Reply to edb:
Hi Robert,
Eddie
Thank you for the information..
I live in Utah.
The dozer spent most it's life on a ranch in Idaho. Then a guy bought a out four years ago and moved it to Utah. I bought it last year. Has been sitting for over thirty years I was told by the last owner. The front main bearing on the starting motor was bad. So I have a feeling that is why it set for all those years. The tracks are frozen.
Been told to put in water.and they should free up
Robert
Wed, Aug 9, 2017 11:21 AM
Crawler Dollars
[quote="robert22"]Hi
The identification tag is missing, was located right upper corner, backside of blade.?[/quote]
I too have the same tilt /angle blade on my D4 7U 38348 and was wondering what the 'Model #' is. I have the 'Caterpillar no. 4A & No. 4S bulldozer manual' but that blade is not shown...only angle and straight blades.
Crawler $
Wed, Aug 9, 2017 9:25 PM
That is the late style 6Fxxxx 4A blade for the 7U.
C-frame group 9F2349 for s/n 6F1342-up
Blade group 9F2348 for s/n 6F1001 to 6F7652 or 6F7654-up (there are two versions)
Brace group (push arms) 9F2346 for s/n 6F2777 to 6F8548 or 6F8549-up (there are two versions)
Tilt arrangement is by one clamping bolt that uses mating teeth for the manual adjustment (pain in the ass to adjust).
Wed, Aug 9, 2017 10:58 PM
Lance Jones
I had one of these on My First Cat, D4 7U 43000 series , and Have a D2 with similar setup . As OM says a pain in the Backside to Keep Tight. D2 Teeth in fact has Been Welded together . LJ
Wed, Aug 9, 2017 11:35 PM
Crawler Dollars
[quote="Garlic Pete"]
Crawler, maybe next time I'm in your neighborhood I can see yours in person.
Pete.[/quote]
Pete, of course! Anytime buddy. When that slick 'Northerner' 7UPuller was down our way, he was eyeball'n 😖py: her, but I kept her at a safe distance :hand: and behind a locked :lock1: gate.
Thu, Aug 10, 2017 5:48 AM
Crawler Dollars
[quote="Old Magnet"]That is the late style 6Fxxxx 4A blade for the 7U.
Tilt arrangement is by one clamping bolt that uses mating teeth for the manual adjustment (pain in the ass to adjust).[/quote]
Pete, correct me if I'm wrong, but the blade pictured doesn't appear to use the mating teeth style adjustment (which my blade uses also) this one appears to clamp differently...appears to use a single clamp bolt that slides within a slot.
Crawler $
Thu, Aug 10, 2017 6:15 AM
7upuller
Reply to Crawler Dollars:
Crawler $
Hey Team,
I have been Alerted that Crawler Dollar$ seems to be picking on me...:laser:... hmmm, does he want to :fencing:...Well, bring it on...:boxing:... He will be met with "Fire and Fury, Frankly...Power"...you see, I have more power than a D4...:target:
Thu, Aug 10, 2017 6:29 AM
Crawler $
[quote="Crawler Dollars"]Pete, correct me if I'm wrong, but the blade pictured doesn't appear to use the mating teeth style adjustment (which my blade uses also) this one appears to clamp differently...appears to use a single clamp bolt that slides within a slot.
Crawler $[/quote]
Yes, the inner and outer panel clamp together with the single bolt and square nut that moves in a slot. The teeth are there to help it hold position. You can just barely make out the top teeth in the picture.
Thu, Aug 10, 2017 12:06 PM
nomorejohndeere
Send a private message to nomorejohndeere
Crawler $[/quote]
In order to avoid the confusion of owning that blade ........... I just hate to see you suffer
I'll take it off your hands
😖py:
Thu, Aug 10, 2017 12:15 PM
