Calling the road-making experts for expertise
Showing 1 to 10 of 23 results
LCA078
Send a private message to LCA078
I need to rebuild a 1/2 mile of caliche road which was an old easement and well built back in the day. I'm thinking I need 200 yards of roadbase to raise the low spots and surface the good areas. The problem is I haven't found a dump truck willing to chain-spread the roadbase due to overhead trees so I'm stuck (right now) with them dumping in random spots and I'll have to spread myself.
So.... What's the best method for spreading road base on a straight run when it's dumped in piles? Dump on side of road then use dozer/grader to push onto the road a few yards at a time? Or dump in center of road and work it down? I'm thinking it'll be hard for a D6C-like dozer to climb on top and then push 3-5 yards through on a 15 yard pile. Am I just wimping out on my thinking on how to use a dozer?
Mon, Sep 30, 2019 8:21 PM
Thank you received: 99
Hi, LCA078.
Firstly, you are wimping out on spreading that material with a 'D6-like' dozer. Dump it on the road and spread it from there. You'll lose less of it.
Secondly, see if anybody in your area has a bottom dump rig and would be willing to haul the material for you.
Mon, Sep 30, 2019 8:31 PM
LCA078
Hi, LCA078.
Deas- thanks for quick reply. Yes, a bottom dump would be lovely but I haven't found one willing to do a small personal job here yet. The trucks would have to back down the 1/2 mile since there is no turn around and no commercial outfit with the bottom dumps wants to mess with this personal job (economy is still too good here).
Back to the dozer spreading issue, how do I spread the 15-yard single pile dumped on the road? Climb on top and push part of the pile down the road in one direction and then do the same in the opposite direction? Just keep whittling it down by passing over the top? I figured I'd just be spilling the base off to the side and make more of a mess this way. Or do I cut the edges of the pile down by pushing the edges onto the road via a diagonal cutting action?
As you can tell, I'm very new to this so just want to learn from the experts.
Mon, Sep 30, 2019 8:58 PM
Reply to LCA078:
For the finish grade get a grader or good drag box behind a tractor and "crown" the drive so the water runs off,[high in the middle and sloped to the sides], you dont want a flat drive or you'll just have pot holes again.
Mon, Sep 30, 2019 9:17 PM
janmeermans
Reply to LCA078:
LCA078,
I can't tell if you already have a D6 or don't own any equipment. If you just want to fix your road on the cheap, rent a Case 580 skip loader with a front loader and rear box scraper. First, attack the piles with the front loader back dragging (with the bucket in a dumped position) in a back and forth motion spreading on the road as you go. Eventually, the pile will be small enough to push through with the front loader. Continue to push the material forward until the pile is reduced. Then use the rear box scraper to grade the road. Where portions of the pile have migrated on to the shoulders, you can pull that back onto the road with the scraper until you get the piles distributed over the 1/2 mile of road.
A dozer will spill material on to the shoulders as you push through the piles. As above, attack the piles with the dozer back dragging to reduce the piles, then push through them starting from the side and working toward the middle. If your skill is just basic, you can probably get by with finishing the road by back dragging with the blade in float. I see you want to buy an old grader which will make the road maintenance easy. Just get one with a scariffier to loosen the caliche so you can grade it out. A Cat 12 or 112 would be about right. Galion made a 118 model which would also work well.
Have fun,
JanM
Mon, Sep 30, 2019 9:26 PM
ETD66SS
Send a private message to ETD66SS
Reply to janmeermans:
LCA078,
Have fun,
JanM
Live bottom is really the only way to go:
https://imgur.com/HwJkTUD
https://imgur.com/f8RDGfW
https://imgur.com/1ae2laU
Mon, Sep 30, 2019 11:26 PM
bursitis
Reply to ETD66SS:
you could always shovel it off! "wink". if you take into account the extra money spent on rental of equipment you could offer a company with a belly dump extra compensation to make it worth while??? have the driver chain the doors so that it will string out.
Mon, Sep 30, 2019 11:34 PM
d9gdon
Reply to bursitis:
If I can't get a belly dump to haul it, I use a D4C to push the edges of the piles down and keep the material in the center of the road with the power angle blade while stringing it out. A box blade tractor can speed that up quite a bit but I use the dozer alone. It can take twenty minutes to string a load out for 100' and not wind up with more in the ditches than in the road. Most ranch roads are around 12' wide and 9" thick. Using a straight blade on a D6 would take longer but is doable. I have built a hundred miles like this. I prefer to dig and haul it with a scraper on bigger jobs where you have or can make a long pit on the property. Most times this is done when building roads for oil well sites and drilling pads.
You need the tracks to walk that rough caliche down into road base anyway. Some that I use is rough as a cob and might come out in 3 foot chunks if it's dug with a trackhoe, while some I use is nice and uniform with fist size rocks down to 3/4" minus. Walk it back and forth several times and it'll work up like crushed rock. Then you can run a motor grader down each edge and pull the cobbles back into the middle of the road and walk em down again until you have some really nice processed material. Then you can come back and put the finishing touches on it with the motor grader.
Tue, Oct 1, 2019 4:00 AM
Cysco
Reply to d9gdon:
Here in Georgia we have spreader trucks lay down gravel. They spread at a smooth even rate …….minimal dressing up.
Just a thought as I'm sure Texas has those trucks as well,
Have a good day...…..Bill
Tue, Oct 1, 2019 4:14 AM
d9gdon
Reply to Cysco:
Yes we do Bill, but caliche is usually very rough material and truckers don't want their trailers beat up with it.
Tue, Oct 1, 2019 5:26 AM
old-iron-habit
Reply to d9gdon:
Regarding belly dumps or live bottoms. If you have a dozer available build a turn around for them at the end of the road first. You will need one anyway.
Tue, Oct 1, 2019 10:04 AM
