cable unit
cable unit
Showing 1 to 9 of 9 results
razz
Send a private message to razz
will the shaft out of a D7e fit a D6c for a 25 cable unit Thank you.
Wed, Jan 8, 2020 7:35 AM
My parts book says 17A1-up uses a 4F2813 shaft (don't know if that would include the D7E)?
D6C uses a 3J4469 shaft. Both for the #25 CCU.
Wed, Jan 8, 2020 10:45 AM
gary in CA
Thank you received: 12
We borrowed a #25 cable unit from a friend that had a 17A for our 47A D7E.The shaft was too short for our D7E.We could not find a shaft anywhere.Ended up having one made as I recall
Wed, Jan 8, 2020 10:55 AM
doylex
Send a private message to doylex
Reply to gary in CA:
Measure your shaft. I have a d6c shaft. Ill take a look and see.
Wed, Jan 8, 2020 6:26 PM
razz
Reply to doylex:
Doylex would you be willing to sell your shaft for the D6c I have the 25 unit and trying to help a guy put it on his D6c he is from nw iowa.
Wed, Jan 8, 2020 7:05 PM
doylex
Reply to razz:
Do you have the 2 spacers also
Thu, Jan 9, 2020 7:10 PM
razz
Reply to doylex:
no he does not have anything I Have a good 25 unit wants to put it on a D6c pull a scraper
Fri, Jan 10, 2020 4:24 AM
doylex
Reply to razz:
Your good 25 unit how is it geared. Your gonna want the 4.11 gears over the 3.55's
Fri, Jan 10, 2020 6:21 PM
razz
Reply to doylex:
not sure its off a D7e can you help him out hes by souix city
Fri, Jan 10, 2020 7:21 PM
old-iron-habit
Reply to razz:
If I remember right when looking for one for my 9U- D6 a D7 and D8 winch is geared higher due to the slower turning engines. The D6 winch is geared lower due to the faster RPMs. It will spin faster and may not work well.
Mon, Jan 13, 2020 9:43 AM
