cable controls
cable controls
Showing 1 to 6 of 6 results
Mervyn Pepper
Send a private message to Mervyn Pepper
Curious if anyone here knows of any differences between the No 25 and the later 125 and 126 cable controls ??
Yes know the 25 was the standard rear cable control for D6 7 8 until the later 127 and 128 cable controls replaced them for D7 and D8. And the 125 became the cable control for D5 and 126 for D6C.
but internally is the 126 same as a 25. Afaik only the adapter plate and pto shaft are different ?
cheers merv
Sun, Feb 23, 2014 4:43 AM
There are some differences in how the mechanism is laid out. Similar, but at least looking through the holes in the side covers where you have to adjust the free travel and brake, things are a little different. A parts book would tell you. Probably the main difference is where the PTO shaft comes into the unit. The one on our D7E is on the upper right side instead of the lower center on the #25, I think it is a #126???
Sun, Feb 23, 2014 5:31 AM
D7E uses a #127 CCU 31E-up with live pto drive shaft.
#126 CCU 32E-up is similar to the #25 with differences that would have to be compared. Uses the same adapter but drive shafts can differ. Main differences are in the height of the control levers to clear the D6B & D6C fuel tanks.
What are you looking to mount unit on?
Sun, Feb 23, 2014 8:29 AM
Mervyn Pepper
Hi OM; isn,t for me but have got a mate with a 25 but he cant find a service manuel; ive got a 32E. 126 manuel; just checking see if anyone knew of any differences in them.
cheers 👍
Sun, Feb 23, 2014 10:43 AM
Reply to Mervyn Pepper:
cheers 👍
If the #25 is a 32E model, it's the same as the 32E #125 and 32E #126.
If the #25 is a 9D501-up model some parts are different but I'd say most of the service information would be applicable. If you have specific part interchanges in mind I can look up and compare the items. I don't have a 32E service manual.
Sun, Feb 23, 2014 2:03 PM
Mervyn Pepper
Hi OM, yes if you have the pinion preload adjustment spec for a 9D would be great thanks
Mon, Feb 24, 2014 3:09 PM
9D Pinion Instructions....
"To adjust the pinion bearings, install the bearing retainer without the shims then check the existing clearance with a thickness gauge or the shims used in the assembly. After the correct amount of shims have been selected, subtract shims, approximately 0.003", to obtain a 5 pound preload between the bearings and the pinion"
Same procedure for the bevel gear bearings.
Mon, Feb 24, 2014 11:30 PM
