Cable control unit model 29 31E6491 where to check oil level
716thMP
Send a private message to 716thMP
I am unable to locate how to check oil level on a CAT 29 dual drum cable control unit SN31E6491. On my Cat D7 3T dual cable control there is a upper pipe plug for adding oil and a lower one for filling to that level. But not on my D7E 48A550 with Cat dual cable control unit.
Any help will be appreciated John
Tue, Nov 8, 2022 9:41 AM
There is a 3/8" pipe plug on the lower left side of the case. It's kinda tucked under.
Tue, Nov 8, 2022 9:55 AM
Fill is the breather on top of the prop shaft gear case.
Level is where the oil smudge is on lower left side.
 [attachment=69455]#29 CCU #4.JPG[/attachment]
Tue, Nov 8, 2022 1:06 PM
