C frame question
C frame question
Showing 1 to 10 of 20 results
MetalmanD69U
Send a private message to MetalmanD69U
Have been looking for a C frame for one of my 9U's, a guy phoned me today offering one off a D6C for $500.00
Anybody here know if the C frame from a C will fit the 9U?
The one he has is located several hundred miles away and I have no time right now to go and measure it.
Price seems right.
Thanks.
Thu, Oct 30, 2014 11:38 PM
I'd say no, to many different part numbers with no interchange.
Your limited to 9U or D6B 44A .
Fri, Oct 31, 2014 7:54 AM
rmyram
Hi metalman, I have a spare c frame and blade sitting here I am willing to part with. pm me if your interested, have some other 9u bits and pieces as well.
Fri, Oct 31, 2014 9:56 AM
MetalmanD69U
Reply to rmyram:
Thanks Old Magnet, I was hoping you'd chime in, your answers carry a lot of weight, even if it was not the answer I wanted to hear!
I figured the D6C would probably not work for me, assume it is a larger machine.
Rmyram I appreciate hearing from you, you offered me some help with engines back in January.
I may need to make a trip up your way to discuss parts before winter if I can get away.
Already have an offer on a pair of C frames + a parts '9U over in Vanderhoof, again if I can make the time to get away.
I have revised my plans and am keeping the 'spare' '9U now, since I have had the opportunity to use it a fair bit this fall and it runs so darn sweet:eyebrows:.
Fitted a hefty 11' clearing blade to it this summer, and am happy as a pig in $--- with it so far.
Took a chance on the blade at an auction, excellent low price, figured I could recoup the cost in scrap if I had to but voila!
New plan is to use the one for clearing and brushing, and the other for grading/spreading/smoothing.
Just need to rebuild or replace the pony engine on my old one.
Thanks again for the help guys.
Fri, Oct 31, 2014 10:43 AM
Reply to MetalmanD69U:
If you can get the blade and it's s/n that goes with the D6C "C" frame I can check further. The whole assembly will most likely work, it's just matching it to the lighter 9U blade that is in question.
Fri, Oct 31, 2014 12:28 PM
johan7
Hello , the D6C frame never fits a D6 9U .
Some years ago I had to fit a D6C C-frame on a 4T D7 . I had to adapt the push arms completely . The C-frame of the D6C is even wider than the D7 was !
Have a nice day . johan7
Fri, Oct 31, 2014 11:02 PM
Reply to johan7:
Hi johan7,
Is it the width (thickness) of the push arms themselves that is the problem? Also I suspect the inside arm to arm dimension is different.
The 9U, D6C and 3T/4T are all the same 74 inch track gauge but mountings are different.
Fri, Oct 31, 2014 11:56 PM
MetalmanD69U
Hi johan7,
Just had another offer of a C frame from a chap with a D7-4T, he is parting it out 'cause the main engine blew up.
For interests sake, would the C frame off a 4T fit a 9U?
Sat, Nov 1, 2014 1:00 PM
Answer is no. Different trunnion, bearing and cap. C frame outside width is 6 inches wider than the 9U.
Different width blade, different braces and angle adjustment fittings etc.
Again you are limited to 9U and D6B 44Axxxx.
Sun, Nov 2, 2014 12:32 AM
MetalmanD69U
Thanks, Old Magnet.
Sun, Nov 2, 2014 2:41 PM
johan7
Thanks, Old Magnet.
Hello Old Magnet ,
It took some time to photograph the C-frame of that D6C . The push arm was straight in the past , but I cut , aligned and welded it so that it was in line with the trunnions of that D7 4T.
I had to move inwards approx 4 cm on both sides .
Have a nice day .[attachment=25902]012.jpg[/attachment]
Thu, Nov 6, 2014 10:42 PM
