Bypass Crank Case Lubricating Oil System
Terence McK
Send a private message to Terence McK
The oil cooler on my D2 is holed and I want to bypass it, to do this I
need to convert to a full flow system by the installation of a cat field change over group. What is this? Pictures I see in my Cat manual show the outlet and return holes to the oil filter housing just blanked off. Is blanking off these holes at the base of the oil filter housing safe? Or does this effect the circulation of oil around the engine? Any help welcome.
Sat, Sep 12, 2009 8:15 AM
You can't just blank them off as it stops the oil circulation.
Do a search for oil cooler lines and filter change overs on here as this was just brought up on a D4 last month so the info is available to explain what and how to do that.
The easiest way is to take the lines from the filter to the oil cooler and interconnect them so the oil comes out of the filter and returns right back in.
Sat, Sep 12, 2009 6:05 PM
Reply to drujinin:
Your talking about three different events here.
The conversion from partial flow (bypass) filtration to full flow filtration using the conversion kit has nothing to do with bypassing the oil cooler.
There are two options for bypassing the cooler. You can rig a bypass loop connection....tubing or hose at the filter base.
or
You can plug the ports directly. If you just plug them it is a good idea to remove the oil cooler bypass valve/plunger from the bottom of the filter housing (under the two bolt plate)
Be aware that the ports are straight thread pipe, 1 inch 14 tpi (not tapered)
Overtightening tapered pipe plugs in these port can crack the housing so beware.
I have recently started using o-ring face seal plugs with an o-ring installed similar to and o-ring boss fitting. The OFS plug is a -10 size with the 1-14 thread.
Sat, Sep 12, 2009 11:42 PM
bcwayne
or
OldMagnet.... do you happen to have a part number for the face seal plug ???? I've searched on McMaster-Carr and can't find it. Thanks, Wayne
Mon, Sep 14, 2009 10:01 AM
Reply to bcwayne:
Hi Wayne,
McMaster is pretty limited on hydraulic fittings......and your not likely to find them in our area unless you know of a good hydraulics house.
O-Ring Face Seal (OFS) dash 10 (-10) size
SAE #520109
Aeroquip FF9767
Parker PNLO
Weatherhead 4229
I get all my hydraulic & hose fittings here
www.discounthydraulichose.com
Their part number is a FS2408-10
Don't forget to add an o-ring to the outside that makes it sort of an 0-ring boss fitting. Discard the face seal if your not using it.
Mon, Sep 14, 2009 10:10 PM
bcwayne
Hi Wayne,
SAE #520109
Aeroquip FF9767
Parker PNLO
Weatherhead 4229
Excellent.... Thank You😊
Tue, Sep 15, 2009 2:01 AM
