Buying a D4 6U
Buying a D4 6U
Showing 1 to 10 of 21 results
rflegal
Send a private message to rflegal
Hi Gents,
I'm a bit new to all of this so please forgive any ignorance on my part. My wife and I are looking at an old D4 6U, we go check it out tomorrow. We have a small 15 acre farm and I want to use it as a "farm cat" to clear some land, move some dirt, etc. Its a 51 according to the farmer who has it, but don't have a serial number yet.
[attachment=7732]3m93pa3le5Q05Z15U1ac8b2f4ba89c4c817f3.jpg[/attachment][attachment=7733]3n93k13mf5V55Q15Z6ac8b508341969e516bd.jpg[/attachment][attachment=7734]3n23mb3p25V65W65R5ac89249453fafd518e5.jpg[/attachment][attachment=7735]3n13mf3l55O35V45Y0ac85ef168fb5f5b1bfc.jpg[/attachment]
I'm a bit of an equipment "saver". I have an old '56 duece and a half (M36), two '59 anglias, a Ford 9N and 8N, a '76 FJ40, a '71 Bultaco Campera, a '71 Mach I, etc. I love old stuff. If it has an engine, I can probably fix it. I would love to add this cat to my collection.
My concern though is... well, this addition would have to earn it's keep a bit. My wife has been very patient with my "collection" but we only have so much space & $$s. So to that end, a few questions if you don't mind.
What are some of the critical things I should look at tomorrow? I know checking out the UC is important, but how, what do I look for? I have downloaded the track inspection info from the Crawler Heaven web page, so I can check for pin and bushing wear and chain wear. I was wondering what the original grouser height was? Also, I've read a great deal about changing out the steering clutches; it looks like no big deal, but how much might something like this cost? My wife asked what the cost of ownership might be, I told her I though it should be somewhere around the same as our Kubota 3830 (just spent about $800 for the 400hr: parts & lube only, my labor!). Also, the farmer says he just had the pony motor worked on to the tune of $500 (don't know what he had done), so apparently he thought it was worth it.
Finally, he's asking $3250 for it. This seems a bit high to me. I have seen these all over the board, from $1000 for a parts basket case to $12,000 for a fully restored. I was thinking more like $2800 if its starts and steers well, given the pony work. Any thoughts? What's fair here?
Thanks for any help guys. - Bob
👋By the way - I'm a mining engineer by profession. I was in charge of a P&H 4100 and a fleet of CAT 793's at one point in my career so equipment is kinda in my blood. Its hard to shake...
Too many projects... too little time
I need a winning lottery ticket... anybody...please?😞
Sun, Jan 2, 2011 12:06 AM
New grouser height is 1-7/8 in.
Can't make out much of anything detail wise from your pictures other than it appears to be complete and in good shape.
At $3,500 plus it would still be a good deal if it runs and steers well and the undercarriage is not worn out.
Be aware these crawlers are known to be money pits and parts/repairs add up fast.
The up side is most parts are still available, new or used. I'd figure about $500 a side for steering clutch and misc. Good luck with the dickering.
Sun, Jan 2, 2011 1:21 AM
tyoos
Send a private message to tyoos
I would say looking at the pictures that it is a 1955 -1959 being that it has five roller
roller frames which on 6U's are vary rare. Looks like most of the tins are there and
they look pretty nice as well.
Thanks, Josh
1954 Cat D4 7U28304SP with cat angle dozer and Hyster D4N winch
1954 Cat D4 7U28174SP with cat HT4 lodaer
1953 Cat D4 6U with cat bulldozer
1946 Cat D2 5J8424SP with Traxson T2 loader 624 and canopy
1954 Cat D311 4V6821 Gen Set
1946 Cat D4400 1S4444 Power Unit
1959 Mack B421 semi tractor with 413 Chyrsler engine
International R190
1939 International D2 pickup truck
Lei Roi Tractair aircompresor
Clark airport luggage truck
1947 Farmall A
1946-1977 20 Gravely Lawn and Garden Tractors
Sun, Jan 2, 2011 1:40 AM
Thank you received: 62
Reply to tyoos:
Thanks, Josh
Another thing to consider is that price of crap is going up again,260 a ton was talked about some were.That put scrap price near 2000 on this machine.I like to buy tractors cheap too,but if it runs,turns,and stops it has to be worth more than scrap.Grouser height is not a big issue to me as I operate in a clay area and if there is moisture the grousers are full of dirt all the time.Rail height and pin and bushing ware are much more important.Grousers can built up with nothing but time, changing rails takes much more labor as well as some lifting equipment. Changing sprockets is another thing that takes specialized equipment that is not sitting around to be had by shade tree mechanics.So that is another area to look close at.Good luck with your hunt for a new working toy.Ray
Sun, Jan 2, 2011 5:52 AM
Reply to Ray54:
Did notice in your first picture that the front idler bearing block appears to be near the end of the track frame....that's not a good sign as it would indicate a well worn undercarriage. If that is a five roller frame my old eyes sure don't see it.
Sun, Jan 2, 2011 9:10 AM
rflegal
Thanks for all the replies so far guys. We'll go look at the dozer tomorrow, maybe take a few pics. Apparently its been kept in a barn, so I should be able to crawl all around the D4. I'm anxious to see the data plate, which I understand should be in front of and above the right foot pedal, yes? Also want to see it started and run.
As I said, this baby will have to earn its keep from day one, nothing big, just pushing some dirt and brush around.
Wanted the grouser height as a indicator for use. Course the tracks could have been replace or repaired at some time, but the dozers at the mine can really show the difference in the track wear depending upon material: the dragline dozer wears the grousers much faster on rock that the dozers pushing dirt on regrade. According to the current owner, he bought it from a rancher to clear some acreage, so my suspicion is that its been mostly in softer material, not much on rock. Still, I have no delusions. It is a 60 year old piece of equipment. I suspect I will be her last owner if we pick her up.
Old Magnet, thanks for the insight on the the front idler bearing block, I'll check it out (wow, you got good eyes...it's a tiny picture!). If its at its end of travel, it means I should see significant wear when I check the pin/bushing spacings, yes? (chain stretch? Worn sprocket?)
As to the scrap price, I'm a bit confused even at $260 a ton, that's less than $1500 and I'm offering $2800. Still seems pretty good to me. Everything I've read seems to indicate it is a buyer's market right now on these machines. Any other thoughts on pricing?
Again thanks for all the help guys... If its not to cold we'll go see her tomorrow (high was 20 today, supossed to be -6 tonight. Brrrrrrrr.):jaw:
Sun, Jan 2, 2011 11:15 AM
Reply to rflegal:
Here is your serial number locations...they should match.
6U machine is about 10,000 lbs plus approx 3,000 lbs for blade and pump.
Yes on your wear assumptions.
Sun, Jan 2, 2011 12:02 PM
rflegal
Thank you so much, sir.
Sun, Jan 2, 2011 12:07 PM
8C 361
Thank you received: 12
Reply to rflegal:
What I like to see is the tracks and the blade are all shined up. This shows the Cat is capable of working and has worked lately.
When checking the chain pitch also determine if the pins and bushings have been turned yet. also take note of the wear marks on the sprocket, see if the bushings have been running towards the tip of the teeth (bad) or near the root (good).
This could give you some bargaining power, you could check with a local track shop to see what a p&b turn would cost.
Mon, Jan 3, 2011 12:53 AM
rflegal
Reply to 8C 361:
Well, we went to check it out. It was 8 degrees out! The owner was exceptionally nice, a current mechanic with the local CAT establishment.
Serial number is 6u-12286. He had put a block heater on the engine when he heard we were coming, had started the pony motor, but it had cooled off by the time we got there. The pony started right up; after a little coaxing and cranking the main came to life as well. Pretty impressive for as cold as it was; within 10 minutes!
As promised, it was in generally good condition for its age. Bad news - The right side track was worn as the adjuster is almost completely extended. Right side sprocket is worn, not too bad I think. The left side looks pretty good.
The good news - pony motor is electric start, there is a generator, regulator and battery. The fuel pressure is good (in the green), the oil pressure is good, and the temp came up well.
The owner says he has an extra set of tracks, too big but that fit (less a link) that he can cut the shoes down. I will have to explore this with him.
I took it for a drive in the snow... oh yeah, it was fun. Hydraulics all function, no obvious leaks. Steered pretty well, slow on the right at first but worked better as it all warmed up. The clutches and brakes all seemed to work pretty good. Forward and reverse was good; stiff as hell in the cold but worked well.
My pics didn't come out great, maybe the cold. I have added some here. Let me know what you think.
Bob
[attachment=7772]P1021591.jpg[/attachment][attachment=7765]P1021599.jpg[/attachment][attachment=7766]Copy of P1021594.jpg[/attachment][attachment=7767]P1021595.jpg[/attachment][attachment=7763]P1021596.jpg[/attachment][attachment=7773]P1021590.jpg[/attachment][attachment=7771]P1021602.jpg[/attachment][attachment=7769]P1021600.jpg[/attachment][attachment=7770]P1021597.jpg[/attachment][attachment=7768]P1021601.jpg[/attachment][attachment=7764]P1021598.jpg[/attachment]
Mon, Jan 3, 2011 11:28 AM
rflegal
Reply to rflegal:
Bob
Forgot to add... owner has a tri-axle, says he can deliver the 45 miles to the farm. Nice guy. I think I've been bitten by a CAT bug... not good.
Mon, Jan 3, 2011 11:38 AM
