Brought Home A 60 Scraper
Showing 1 to 10 of 12 results
bosco
Send a private message to bosco
Found this in the weeds and brought home the other day. Looks kinda small next to my grader, but should clean up well.
Any info on this scraper would be appreciated.
I looked for the s/n, but could not find one. I found on the neck where a small
tag is missing. Also on the neck was welded X-199 on each side.
It has the same tires front and rear, but I want to put the larger size on rear
like it should be.
What size should be on the rear and are they readily avaliable or hard to find?
Long term would like to restore back to cable use or convert to hyd.
Would like opinions on which way to go, I see plenty that are converted and
wonder if they are worth more restored original or converted.
Thanks for everybodys input.
Thu, Nov 4, 2010 2:59 AM
Thank you received: 46
That would be a 1Dxxxx model. Might have the number stamped where the tag is missing if you scrape around a bit.
Don't think it matters much converted or not so long as it's working.
Thu, Nov 4, 2010 3:16 AM
D6Joe
Send a private message to D6Joe
converted to hydralic and decent tires, it would bring $15,000 at auction sales up hear in eastern ND
Thu, Nov 4, 2010 3:50 AM
D6c10K
Send a private message to D6c10K
Reply to D6Joe:
Would like to fine one like that or maybe a 70 and a CCU for my D6c.
Thu, Nov 4, 2010 7:05 AM
7upuller
Reply to D6c10K:
Nice find, cut the side boards off, back to stock. Here is a link to some of mine-glen
http://www.youtube.com/watch?v=Plu9p3Rgr6I
Thu, Nov 4, 2010 8:28 AM
harvest
Send a private message to harvest
Reply to 7upuller:
What you have is a Caterpillar "round bottom" #60 cable scraper. As mentioned before, it is a 1D-xxxx serial number. The tires are typically 16.00x20 and are readily available--especially radials from military take offs. Parts are available from most Cat dealers.
If you need parts/tires, give me a call: 419-420-1551
Erik
Wed, Dec 8, 2010 10:03 AM
Chappy
Send a private message to Chappy
Reply to harvest:
Erik
Only 110 degrees yesterday here in Southern California so I decided to put another set of 16:00 x 21 tires on the Cat 60. Sunny and Hot, perfect for warming the rubber up.
Chappy
Mon, Aug 12, 2013 4:04 AM
Kelly
Bosco,
As said you have a 1Dxxxx cat 60 scraper. If you have trouble finding the Sn a little paint remover in the area of the two small holes where the Sn plate was, should help in finding the same. Another thing is to check the rear axle on the left, if it has an adjustable (eccentric offset) axle used for leveling up the cutting edge it more than likely a 1D1089 or later. The eccentric offset axle become effective with that Sn for the 1D series 6O scrapers.
The tires with the diamond pattern were known as the “All Weather” tread. The Cat 60 had 1400X20 on the front and 1600X20 on the rear.
Kelly
[attachment=19002]Cat60axlereara.jpg[/attachment][attachment=19003]Cat_scraper_tires_all_weather_jpg.jpg[/attachment]
Tue, Aug 13, 2013 6:55 AM
d9gdon
Reply to Kelly:
Bosco,
Kelly
Kelly, don't know if you noticed but this thread was started nearly 3 years ago.
Tue, Aug 13, 2013 9:20 AM
Mervyn Pepper
Send a private message to Mervyn Pepper
Reply to d9gdon:
interesting pic there Kelly, that scrapers either a LaPlante choate or allis chalmers, definitely not caterpillar. You can see the apron-ejector hinge lever in the pic that only they used. Mayby a 314 or 315, tractor might be a HD19 or 20 ???
Tue, Aug 13, 2013 12:58 PM
Chappy
[quote="Garlic Pete"]Were those 16.00 x 21.00 or 16.00 x 20.00?
We need two 16.00 x 21.00 for our No. 10 behind our DW10. I would really like to find some diamond tread, which is what I have now. They still hold air for now, but all the sidewall strings are hanging out and it won't be long before they blow out. If you found 16.00 x 21.00 I'd sure like to get a line on two more. Call me or email me if you have any advice (661) 343-3691 or pbloom (at) ymail.com.
Thanks,
Pete.[/quote]
Pete, I still have the tires for the DW10's that we talked about a couple of years ago.
Wed, Aug 14, 2013 5:13 PM
