Broken off roll pins in D2 rollers
Showing 1 to 10 of 10 results
bpusmc
Send a private message to bpusmc
Any suggestions for removing the broken off roll pins shown in the photos below?
 [attachment=69546]EA5150DE-479A-4FD2-8646-57BE8CE66D31.jpeg[/attachment] [attachment=69547]197DA376-B1F4-48E6-B90D-BA928016A7AE.jpeg[/attachment]
They are the type that have to be pulled (cannot be driven out the other side).
I tried drilling them but made no progress.
Wed, Nov 16, 2022 10:02 AM
Thank you received: 54
try artu drills they are made for drilling tough material.
is that supposed to come apart though?
Wed, Nov 16, 2022 2:11 PM
PhilC
Reply to trainzkid88:
They are going to be a nightmare to remove. Even if you had a drill that would drill them keeping the drill on center will be a problem. Looking in the parts manual it shows they are not supposed to be roll pins but solid pins.
Wed, Nov 16, 2022 2:29 PM
Reply to PhilC:
a tri flute drill could do it but only if you could get one to drill that kind of steel roll pins are high tensile. and if you could get one in the right size. ive only seen drawings of them.
actually a carbide or ceramic end mill might work and a mill would have the accuracy and allow the clamping of the part if you can get one the right size.
slightly smaller might allow you to collapse it with punch and drift and remove it that way.
you could try welding a peice of round bar into the pin so you can get a slide hammer on to it but do it wrong the part is probably ruined beyond salvage.
Wed, Nov 16, 2022 5:26 PM
Try turning a metal screw in that just turns in easy or a thread tap, and small screw then use a vise grip slide hammer or make something like it, easy does it though, worth a try, may or may not work.
Wed, Nov 16, 2022 8:02 PM
naylorbros
Thank you received: 31
I had a similar thing on the rollers on my Thirty, except they were dowel pins. They were worn off smooth with the surface of the roller. I welded 1/4” nuts on top of the and then pulled them out.
Ken
Wed, Nov 16, 2022 9:16 PM
bpusmc
Thanks for all of the suggestions.
It must be my lucky day - I got all six out without incident!
  [attachment=69556]171C41D3-4E0B-4B89-A9F0-032CA26F7DE0.jpeg[/attachment][attachment=69557]75E84726-A72A-436D-8A67-D7CB0506093B.jpeg[/attachment]
Chad
Wed, Nov 16, 2022 11:44 PM
Reply to bpusmc:
Chad
Bravo!!!!!!
Thu, Nov 17, 2022 12:59 AM
gauntjoh
Librarian
Reply to bpusmc:
Chad
Well done! Is that a screw extractor you used on the end of your slide hammer?
Thu, Nov 17, 2022 1:06 AM
Reply to gauntjoh:
Looks like my Harbor Freight slide hammer dent puller!!!! Good job!!!!!
Thu, Nov 17, 2022 1:28 AM
Kurt Bangert
Thank you received: 43
Sweet! Love it when a cross-your-fingers-and-hope-it-works plan comes together!
Thu, Nov 17, 2022 1:44 AM
