Broken Crank 3406
Broken Crank 3406
Showing 1 to 10 of 21 results
955H
Send a private message to 955H
A friend of mine bought an older highway tractor, and discovered afterwards that it has a broken crank: obvious question i guess but how does a crank that i would think would be alloy (forged) steel get broken? is it a mechanical force that breaks it or a chemical action (not enough maintenance?) and acids in the oil find a weak spot? it had a approx 800,000 miles on it. i have a newer one that had almost 1,000,000 on it before it was overhauled and its still going strong.
KEVIN JOHNSTON
955H, D7-17A, JD 540 SKIDDER W/JD BACKHOE ATTACHMENT AND LOTS OF COCKSHUTT TRACTORS
Thu, Sep 24, 2009 8:13 PM
catsilver
First thing that comes to mind is the front damper, if it has been damaged at some time, it can break the crankshaft, I wonder i fthe truck has ever had front end damage, also damaging the vibration damper?
Fri, Sep 25, 2009 3:22 AM
Reply to catsilver:
Most high speed crankshafts, especially long ones, need a system to damp torsional vibrations while they are running at certain rpm ranges. The rubber mounted weights bolted to the front pulley damp the vibrations before they can build up to destructive levels. An old, stiffer or softer than normal damper will not function like a new one. As catsilver mentioned, external damage to the damper might cause a sudden failure in the damper function, followed at some point by crankshaft failure.
Some engines probably should have a new one installed at overhaul or certain age/hours. I know some of the larger old JD tractors with the 531 and 619 6 cylinders had a bad reputation for crankshaft/bearing problems and some mechanics will not warranty an overhaul unless the damper is replaced.
Fri, Sep 25, 2009 8:40 AM
955H
how can i check the dampners on my engine, im not sure of what to look for
KEVIN JOHNSTON
Fri, Sep 25, 2009 8:49 AM
Glen Hayward
Send a private message to Glen Hayward
Reply to catsilver:
I remember my Diesel Engine Instructor who worked for Finning ( Cat ) for years told us about a D8 (I believe ) that had a miss in #6 cylinder. After eliminating other possibilities he pulled the side covers off and found that the crank had broken just behind the #6 main bearing and turned and jammed, hence the miss ! I Imagine it is extremely rare (especially Cat ) but happens !
Fri, Sep 25, 2009 8:54 AM
abram
Send a private message to abram
Reply to Glen Hayward:
wow you would think they would have noticed either the accessories/crank pully not turning or the tractor not movin!! (wherever #6 is)
3J5 D2
Fri, Sep 25, 2009 12:46 PM
Glen Hayward
Reply to abram:
The engine still ran,the crank fractured, turned slightly,until the peaks of the fracture jammed together "welded" thus placing the crank throw of #6 cylinder out of time a few degrees, thus the miss when the engine was running ! It was not a clean 90 degree cut but a fracture at somewhat of an angle.
Fri, Sep 25, 2009 11:16 PM
catsilver
I remember, many years ago, my father pulled in with to the works garage with his truck, a 1948 AEC 'Matador' complaining that the engine was running 'out of step'. He was told that there was nothing wrong with it and to carry on, after 30 miles he called the mechanics out because it was getting worse, so they towed the truck back to the garage and dropped the sump to find the crank was broken diagonally across the centre main bearing!
In recent years we rebuilt two 3208 engines which had damged crankshafts in the same boat, after overhaul, the owner claimed they vibrated, after many checks, I went to take a look and found the vibration dampers were both marked, and on checking their history, I reckon they were damaged on the truck that delivered them ,when the engines hit a block of wood behind thhe headboard under heavy braking. The lesson is, if you have a crankshaft failure or the damper has any visible damage, change it!
Sat, Sep 26, 2009 5:20 AM
rigandig
Send a private message to rigandig
Reply to catsilver:
I read an article in an industry newspaper some time back concerning harmonic balancers. It basically said the same thing regarding any damage to the balancer, replace it. It also went into detail explaining the wear that takes place in the older balancers that had the "ball bearings" in oil, and how they, as any metal part, over time will wear. This , in turn, will cause the balancer to become less effective in it's performance. If memory serves me, the mileage that was given to change the balancer was in the 800K range. I have 2 trucks , both with 3406E's. I changed both balancers. The new ones from Cat were an updated version. After installation, there was a noticable difference in the amount of vibration that I could feel with the engines at an idle. I can only guess that I may have saved myself a larger repair down the road.
Sat, Sep 26, 2009 8:22 AM
955H
Reply to rigandig:
so whats involved in changing it? can it be done without pulling a bunch of components?
KEVIN JOHNSTON
Sat, Sep 26, 2009 8:41 AM
Reddoug
Send a private message to Reddoug
Reply to 955H:
If it is a vicious damper and you have an infared heat gun, with the engine cold, check the temp of the damper. Warm up the engine and recheck the temp of the damper. If is does not change, the camper is not working properly.
Sat, Sep 26, 2009 10:00 AM
| Kingaroy, Queensland
