Bridge collapse and Big Cats...
TimT
Send a private message to TimT
Tioga Center NY, today we pulled a bridge span that had collapsed due to heavy flooding on Tues. Four 583's and Two big excavators "used as anchors" were used to pull the 100 foot and 150 ton span from the creek. It was very hard pulling to break it loose from the creek bottom and lift and pull it over the concrete abutment. All went well though.
[attachment=50772]DSCF3740.jpg[/attachment]
[attachment=50773]DSCF3742.jpg[/attachment]
[attachment=50774]DSCF3747.jpg[/attachment]
[attachment=50775]DSCF3752.jpg[/attachment]
[attachment=50776]DSCF3755.jpg[/attachment]
[attachment=50777]DSCF3762.jpg[/attachment]
[attachment=50778]DSCF3765.jpg[/attachment]
[attachment=50779]DSCF3767.jpg[/attachment]
[attachment=50780]DSCF3769.jpg[/attachment]
Thu, Sep 20, 2018 9:31 AM
I enjoy seeing the work that your Company does!
Its impressive to see the rigging expertise that goes into the seemingly impossible projects that get done!
Thank You for taking the time to document and present these clean up projects!
Thu, Sep 20, 2018 6:22 PM
seiscat
Reply to drujinin:
Thanks for posting the pics TimT, Getting that span out of the creek is impressive. Replacing the span will be a chore too!
Craig
Thu, Sep 20, 2018 9:44 PM
Reply to seiscat:
Craig
what caused the span to collapse? abutments get washed out, or high water and flow with debris catching on the thru girders?
Fri, Sep 21, 2018 12:12 AM
TimT
Reply to dpendzic:
The abutment was washed out completely on one end by the flow. The Susquehanna river is at the mouth of this creek, the main river was also very high so water was very fast and deep, not much place for it to discharge.This whole area has had bad flooding many times over the years.Its all river valley in NY Southern Tier.
Fri, Sep 21, 2018 4:36 AM
catskinner
Reply to TimT:
TimT,
Thank you for posting the pics. I enjoy things like that very much. Keep them coming. catskinner
Fri, Sep 21, 2018 8:42 AM
