Brake Fluid for 922B?
SwampYankee
Send a private message to SwampYankee
Lost braking ability on my 922B at a rather inconvenient moment the other day. After changing my pants, I checked the master cylinder reservoirs and both had no visible fluid levels in them. The old manual calls for SAE 70 R3 brake fluid. Is there a modern equivalent I can use? I don't know what's in there now (or not in there, as the case may be) because I just acquired this machine a few months ago and did not get any info on the fluids from the previous owner... any help would be greatly appreciated. Thanks!
Matt
Thu, Nov 15, 2012 2:45 AM
Soapy
Send a private message to Soapy
Matt,
You might think about changing to a DOT-5 fluid, which is silicone base , and does not attract moisture like DOT-3 does. This involves a complete draining and flushing the system.
Ed
Thu, Nov 15, 2012 5:19 AM
Thank you received: 39
Reply to Soapy:
Matt,
Ed
I run the silicone based stuff in all my old cars and trucks....rubber parts last forever as well as the corrosion control advantage.
Thu, Nov 15, 2012 5:23 AM
SwampYankee
Thanks. I will give him a dot 5 infusion and hope the braking issue clears up simple. Much obliged.
Matt
Thu, Nov 15, 2012 8:18 AM
