Bosch Mag nomenclature
Showing 1 to 6 of 6 results
mog5858
Can someone tell me how to read the model numbers off Bosch mags? I'm working on a D318 pony. It has an MJK 4/2 360C-410. The first part is easy, but what do the numbers after the 360 mean, as I got mags that are a - 47.
Is there a cross-reference sheet to go from Cat part
numbers to bosch numbers on the mag? The mag I have will run the pony at idle and rev up a little, then falls on its face wont let the pony rev up say 1800-2000 rpm.
Sun, Nov 22, 2026 10:42 PM
Thank you received: 95
OldCroak magneto has many service manuals and advice for many brands of magnetos--link is to Am Bosch MJK Service Manual.
https://oldcroak.com/mjk-ed-a-b-c-service-manual/
Sorry, best I have at this time.
Remember, Google is your friend.
Due to some fluke I managed to copy and paste this from a Google search the AI answer to your query:-
American Bosch magneto designations combine a model/series code, cylinder/application number, edition/rotation/timing suffix, and an OEM specification number (for example, MJB6A-302 or U-4 Ed. 2). [1, 2, 3]
1. Series and Model Letters
  • Early / Armature-Wound Series: Models such as DU, U, ZR, AT, and ZEV used rotating shuttle-wound armatures or early high-tension designs for vintage cars, trucks, marine engines, and early tractors. [1, 2, 3, 4]
  • MJ Series (1930s–1940s+): Introduced stationary coils, stronger magnets, and fewer moving parts:
    • MJA: Largest and highest-output standard MJ model.
    • MJB: Mid-size rotary model with a smaller rotor, coil, and bronze sleeve bearing.
    • MJC: Compact, lower-cost model built for smaller, lower-compression engines.
    • MJH: Later MJ-family variant (introduced around 1948).
    • MJK: Heavy-duty unit built specifically for Caterpillar diesel starting ("pony") motors.
    • MVA: Lower-volume variant used on select small/utility engines. [1, 2, 3]
  • MR / MS Series: Later rotary magneto families (such as MRA, MRB, MRD, MRF, MSA, MSB) with internal variations depending on fixed or variable timing and breaker/condenser layouts. [1, 2]
2. Cylinder Count and Configuration
  • On many multi-cylinder designations, a numeral indicates the number of cylinders served—such as 4 or 6 in U-4, U-6, ZR4, ZR6, MJA6B, or MJB4A.
  • Some catalog listings also show cylinder/type numbers like 2C or 4C depending on the specific tractor or industrial application. [1, 2, 3]
3. Edition, Timing, and Rotation Suffixes
  • Edition (Ed. / letter): Indicates design revisions or sub-series (such as Ed. 1 vs. Ed. 2 on Type U magnetos, or edition letters A, B, C, D on MJ/MJC components). [1, 2]
  • Rotation / Timing Marks: Service and installation references note direction/timing conventions—such as C for clockwise and CCW / A / ACLW for counterclockwise—alongside fixed vs. variable timing configurations and impulse couplers (such as ICA or ICB). [1, 2]
4. Dash / Specification Numbers
  • Numbers after a hyphen (such as -106, -302, or -146 in MJA6B-106, MJB6A-302, or MJC4C-146) identify specific OEM/customer build variants (drive gear, impulse, mounting, or timing specs) rather than a single universal code. [1]
For historical catalogs and service notes, see American Bosch Magneto Catalog 1945 MJA MJB MJC MVA MJK, Magneto Rx: - American Bosch - MJC - Old Croak Magneto, and American Bosch Magneto Partd. [1, 2, 3]
If you have a specific stamp or tag code from a magneto, share the full characters along with the engine make and cylinder count so I can help narrow down its series and application.
  • Old Croak Magneto
    American Bosch MJ Series: Introduced in the 1930s featuring a stationary coil, stronger magnets, fewer moving parts, and shared se...
Sun, Nov 22, 2026 11:18 PM
GrantJ
Thank you received: 13
I have used "OLD CROAK MAGNETO" several times and found them very good and reasonable.
Mon, Nov 23, 2026 3:02 PM
Thank you received: 289
Have you checked the movement of your governor lever? Sticky/binding?
Mon, Nov 23, 2026 3:36 PM
A,B,C,D are the model numbers. There are subtle changes in the internals of each with the "D" models being the most refined.
The last numbers are for the application, see attached list.
Mon, Nov 23, 2026 6:13 PM
mog5858
Thanks for all the great info. Surely I should be able to figure something out. Yes, I did check the governor to no effect.
Tue, Nov 24, 2026 12:17 AM
gauntjoh
Librarian
Thank you received: 8
There are lots of documents in the library on Bosch magnetos…
Tue, Nov 24, 2026 9:18 PM
