Bosch Direct Lighting Generators, Need Info
dick
Send a private message to dick
Does anyone here happen to know how or have instructions for changing the rotation and adjusting the regulator on the American Bosch direct lighting generators? I have lost the fellow who always did this for me and I don't know how, should have learned years ago. I am always watching for adaptors and gears to fit different models of Cats.
Thu, Apr 28, 2011 9:28 PM
I have the Bosch info on the ARKF generators.
Reversing rotation involves swapping the field coil leads (red & blue) and changing the oil slinger hub to one with the correct thread rotation.
Regulator adjustment requires a voltmeter hooked up between ground and the external terminal block of the regulator base.
Adjust voltage at 1000 rpm to 6.0 to 6.3 v by turning the adjustment nut. No external load applied.
Run at 2500 rpm, adjust voltage to 6.3 - 6.4v using the reverse current screw (the one just above the adjusting nut).
Connect three 21 candle power lamps in parallel between terminal block and ground and recheck regulating voltage as outlined above.
Thu, Apr 28, 2011 10:47 PM
dick
Thankyou Old Magnet, just what I needed to know. Now to get it done. Dick
Fri, Apr 29, 2011 8:23 PM
Frank Fox
Send a private message to Frank Fox
Reply to dick:
The instructions for reversing the rotation is printed inside the V/R cap. At least on mine.
Frank
Sat, Apr 30, 2011 11:54 AM
dick
Reply to Frank Fox:
Frank
I have seen that in the past but not on ones I have now. Found out Oz Dozer had put complete manual instructions in the archives several years ago.
Sat, Apr 30, 2011 8:10 PM
Reply to dick:
Glad to hear that. I wasn't looking forward to dismantling a 6 inch thick binder to copy the material when the next question came.
Sat, Apr 30, 2011 10:25 PM
