Bolt for D6 9U track pads
John from Fresno
I need to put another set of pads on my D6 9U. Where can I find new bolts and nuts inexpensively? The ones on there have square nuts.
There are 40 pads per side and 4 bolts to the pad. So I need 320 bolts and nuts.
Thanks,
John
Mon, May 16, 2016 7:50 AM
4tcompost
Send a private message to 4tcompost
A few years ago, when we did a newer D4 we shopped around for prices & CAT dealer was the cheapest
Mon, May 16, 2016 8:42 AM
old-iron-habit
Reply to 4tcompost:
I also have found Cat bolts to be in line or cheaper than other good bolts. I use them on non Cat projects all the time.
Mon, May 16, 2016 9:30 AM
Thank you received: 11
Reply to old-iron-habit:
Is Miller Track service in Modesto still going? They were Berco dealer and used to be a good place to deal with.
Mon, May 16, 2016 10:44 AM
7upuller
Reply to Ray54:
Hey Team,
Charles Miller just did my 14-a tracks. He is teamed up with Phil Fenelli
(209) 216-8435
They did a great job for me.
Glen
Mon, May 16, 2016 11:08 AM
John from Fresno
Reply to 7upuller:
Hey Team,
(209) 216-8435
Glen
Well,
I ended up getting the bolts from Dana at Florin Tractor.
Now, I have a new dilemma. I was swapping the good pads from my donor D69U to my running D69U. I was putting the old slick pads on the non running donor tractor so I would be able to move it around easy. Well I had two old pads left over. I hadn't finish putting the good pads on the running D69U. So I go count the links on the running tractor, and count he links on the donor tractor. The donor had 39 links compared to 40 on the running tractor. So, now, I am short two good pads.
I am looking for 2 D69U pads that are 20" wide and the grouser is 2" tall (measured from the back side). Anyone have a couple on a parts tractor??
Thanks,
John
souzaj3 at yahoo dot com
Mon, Jun 20, 2016 4:50 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
