blocking off D47U coolant passage
CatsMeow
Send a private message to CatsMeow
Hi everyone!  I've got what I believe is a 1956 model 7U (serial 37449).  I've removed pony because teeth on the magneto let go & I figured I'd need to find them all plus take the opportunity to rebuild it.  Well, it's been welded at least twice & for the cost of rebuilding, I've opted for electric start conversion.
My question is if I build plates to seal off the coolant passages that used to supply pony & diesel head, will that be bad for the diesel engine?  I can't tell from drawings if coolant flow through pony is in series or parallel to the main.  Any advice on blocking these off for electric start conversion is appreciated!
She's not pushing up daisies!
Tue, Jul 23, 2024 3:46 PM
side-seat
Thank you received: 15
Won't be a problem. I have a direct start late model D2 that the hole in the bell housing is welded shut and the head has a plate bolted on. The battery tray bolts onto the bell housing where a pony motor would have been bolted on. The coolant still circulates through the head to the block weather there's a pony or not.
Tue, Jul 23, 2024 8:27 PM
CatsMeow
(1 year later) Follow up: thanks side seat, I went ahead with the ports blocked & a new temp. gauge proves good cooling!
Mon, Feb 16, 2026 12:58 AM
MSTEC STEAMFEST
