block off plates-pony motor removal
Showing 1 to 9 of 9 results
mikedell
Send a private message to mikedell
Started making the block off plates over the weekend and got them installed, built a gasket for the area where the pony motor was but now I am unsure about the pressure where the coolant came though to the pony. I made my gasket solid and I am hoping it will be fine, but do any of you guys know how much pressure there is in that area? and if leaking is a issue?
[attachment=23229]plate.JPG[/attachment]
[attachment=23230]plate1.JPG[/attachment]
Mike
Mon, May 5, 2014 2:11 AM
Thank you received: 77
Mike,
if you don't need that pinion handle anymore, I'll take it.
Mon, May 5, 2014 4:15 AM
mikedell
Mike,
[quote="Neil"]Mike,
if you don't need that pinion handle anymore, I'll take it.[/quote]
Hey Neil,
As far as I'm concerned you can have it, I want to take the rest of the pony motor stuff off, but how the heck to I get it out? lol,
Have any helpful instructions for easy removal?
Mike
Mon, May 5, 2014 5:25 AM
catsteve
Send a private message to catsteve
Reply to mikedell:
[quote="Neil"]Mike,
Hey Neil,
Mike
Hello Mike.
I made the plate a few years ago.
The first plate i made was too thin (maybe 1/😎 It tended to warp/move too easily and leaked despite my efforts.
The second plate was about 3/8 thick. I used a CAT gasket and plenty of gasket goop particularly around the bolt holes. Torqued it down evenly and it has not leaked ever again, Despite running pretty hot some days.
Good luck
steve
Mon, May 5, 2014 6:21 AM
Reply to catsteve:
Hello Mike.
Good luck
steve
I use two 3/8" plates. The first one I drill for the bolts and dowels. The second plate I over bore the holes to recess bolt heads and allow enough room for a socket. End product gives a flat deck for batteries.
Mon, May 5, 2014 8:26 AM
Just undo the four bolts, spray lots of loose juice around the gasket area and inside the clutch housing in the direction of the big o-ring that gets tight over time - lots of wiggling. On e it gets wet, it'll slide right out
Mon, May 5, 2014 8:55 AM
mikedell
I really like that idea OM, I think I may have to redo this this plate and go with your idea. Thanks!
Mike
Mon, May 5, 2014 9:00 AM
mikedell
I almost have it out, sprayed some more wd40 on it and letting it sit till tomorrow, Ill send a pm to ya for your address once I get it out.
Mike
Mon, May 5, 2014 9:01 AM
Reply to mikedell:
Mike
Make the top plate large enough to accommodate the size batteries your using, mine pretty much run from fender to fender on the D4.
Mon, May 5, 2014 9:41 AM
Thank you received: 93
Hi team,
tests I have done in the past on 3306 engines showed the water pump could generate some 8-9 psi pressure rise.
So these old darlings may make in the order of 5-6 psi.
If you have a pressurised system then you must add that system pressure to the pump rise pressure for the total effect applied to your plate.
Only actual testing will give a definite answer.
The thing to be aware of that even though 5-6 psi plus system working pressure, does not sound much, when you apply it to a largish area it can generate a lot of force to distort things enough to leak.
Mon, May 5, 2014 12:20 PM
