Block Heater for Cat 12 Grader D318
Showing 1 to 10 of 11 results
KansasD7
Send a private message to KansasD7
I would like to add a block heater to my electric start D318. The coolant temperature sensor thermocouple sensor block plug would be a perfect place to put a block sensor, but I hate to give up the coolant temperature gauge, even in the winter.
Not a big fan of those heaters that go inline with a radiator hose, especially for a big engine like this, but I know that is another option.
Kat's makes 1/2" NPT and 3/4" NPT screw-in heaters that I use on other equipment if I can find a place to install.
Am I missing an obvious place to put a screw in block heater? Anyone ever share the port that the coolant temp sensor uses by installing a tee and installing both the temp sensor and the block heater? Kind of kludgy, but might work.
Thanks,
Steve
Thu, Dec 8, 2016 8:41 PM
kracked1
Don't know on that style. Went block drain to thermostat block with a tank style on ours. Works very well.
Thu, Dec 8, 2016 9:17 PM
Thank you received: 63
Reply to kracked1:
Tap into the two bolt flange on the water pump/thermostat housing and connect other end to block drain.
Thu, Dec 8, 2016 11:11 PM
kracked1
That is exactly where I went. Had to put a T in the 2 bolt flange since that is where the cab heater was hooked also.
Fri, Dec 9, 2016 12:14 AM
oldbeek
[quote="KansasD7"]I would like to add a block heater to my electric start D318. The coolant temperature sensor thermocouple sensor block plug would be a perfect place to put a block sensor, but I hate to give up the coolant temperature gauge, even in the winter.
Thanks, Do not put a t where your temp sensor is. Your temp will not read correctly.
Steve[/quote]
Do not put a tee where your temp sender is. Temp gauge will not read correctly.
Fri, Dec 9, 2016 1:06 AM
Thank you received: 138
Reply to oldbeek:
Steve[/quote]
Hi, KansasD7.
You could also move to a warmer climate. I live in shorts and T-shirt year round here. LOL. That 2-bolt flange to block drain arrangement sounds like a good one to me. I also suspect that the lower down you can locate the heater, the better it will work. But what would I know? They're pretty much unheard of around here.
Fri, Dec 9, 2016 4:53 AM
KansasD7
Sounds good. Found the two bolt flange on the water pump, but can you help identify the location of the "block drain".
Thanks,
Steve
Fri, Dec 9, 2016 6:39 AM
Reply to KansasD7:
Thanks,
Steve
Left hand side of the block, just past/slightly below the governor housing. It is a gasketed machine thread plug, not pipe thread.
Fri, Dec 9, 2016 7:07 AM
kracked1
Mine was already pipe threads.
Fri, Dec 9, 2016 7:56 AM
Reply to kracked1:
Started out as a S-1620 cap screw (1/2" x 3/4" NC) and 4F9325 gasket.
As I recall it required a shorted pipe tap to cut a pipe thread before the tap bottomed out in the drain passage.
Fri, Dec 9, 2016 10:27 AM
sdmuleman
Send a private message to sdmuleman
Hi, KansasD7.
[quote="Deas Plant."]Hi, KansasD7.
I also suspect that the lower down you can locate the heater, the better it will work. [/quote]
Agree with this. You want the heater low - you'll get some degree of natural circulation within the system as the hot water rises and cooler water takes its place. If you have it high you'll just keep heating the same water and potentially start to form steam bubbles causing problems.
Fri, Dec 9, 2016 11:17 AM
