Bleeding/priming D7 17A
reidrhollander
Send a private message to reidrhollander
17A9741
I ran it out of fuel last night like an idiot. Today of course I can't get it started and to make matters worse I have 490 belly dumps of fill coming into the property while I type. Is there a bleed/prime procedure that I need to do to get it started again?
Thu, Feb 18, 2016 12:41 AM
Dick Tucker_archive
Send a private message to Dick Tucker_archive
You can loosen the fuel lines off of the fuel injection pump that goes to the injectors and turn the engine over with the starting engine with the compression release in the run position with the throttle open. This will work the air out of the system. As soon as you don't see air bubbles coming out of the injector lines that you loosened you can tighten them back while still cranking the diesel engine. It should start firing on each cylinder as you tighten the lines.
Thu, Feb 18, 2016 12:54 AM
7upuller
Reply to Dick Tucker_archive:
Hey 17-a,
Call me
415-720-5936
Glen
Thu, Feb 18, 2016 12:58 AM
reidrhollander
Thanks, this worked perfectly and had me up an running in about 5 minutes. I could only reach two of them without taking the hood off but that seemed to be good enough.
Thu, Feb 18, 2016 5:18 AM
Dick Tucker_archive
Reply to reidrhollander:
That is all it usually takes if you get two cylinders firing the others will pickup without bleeding the air. Glad you are up and running. This has happened to me several times so don't feel bad.
Thu, Feb 18, 2016 5:24 AM
