Blade lift Ram 1.25" thread Torque Spec/ Reseal
kittyman1
resealing/rebuilding leaky blade lift hydraulic cylinder(s) on D6c/d....nut holding piston on shaft is 1.25" thread, 12 tpi...was hard to remove but not crazy
-what torque does Cat recommend?  is 1000 pounds torque enough?
-any other tips?
Mon, Aug 15, 2022 12:54 PM
Says to lubricate and tighten [new] nut to 1200 ft lbs +-120 ft lbs.
Tue, Aug 16, 2022 12:52 AM
kittyman1
thanks Rome, 1200 ft pounds it will be
Tue, Aug 16, 2022 1:16 AM
Reply to kittyman1:
Your welcome!
Tue, Aug 16, 2022 2:21 AM
| Kingaroy, Queensland
