Bill Glenns Classic Plant
Showing 1 to 10 of 40 results
tctractors
Heres some pics of jobs ive done recently, i will add more info when i have more time presently.
Fri, Sep 14, 2007 7:59 PM
196200
Send a private message to 196200
Hey TC
Were you tearing apart that dozer scavenging for parts or are you trying to put it back together into something usable based upon someone else taking it apart and giving up. 😛
Fri, Sep 14, 2007 10:19 PM
tctractors
Reply to 196200:
Hey TC
Bill I had my son post up the pics while I was at work on a site just off J-4 of the M5 motorway, sadly he has not put all the pic's up, the D6-High Drive is without doubt the biggest wreck of a blade I have ever seen, all it needed was an engine repair (in frame), the Co's own fitters thought (I don't know why????) to remove the cabin , the transmission,all sorts of hydraulic parts, split one track, also swap the engine with one more Knackerd than the original, then strip both engines and the transmission,then throw all the bits in the Sh*t , then ask me to put it back together for them !!!! I still cannot quite get my head around the damage they have done,
the other pic's are of a D8H 68A F/drive, A Komatsu D65-12 F/drive, and a 963B shovel that I fitted a new under-cart to also refurbished the drive hubs,
I have said yes to the job of re-building the little D6H LGP as I like a bit of sport, If I don't take on the job it will probably end up as scrap, the running gear is first class "WHAT A MESS"
blowing it on tctractors
Sat, Sep 15, 2007 2:34 AM
196200
Reply to tctractors:
Hey TC,
I have some extra parts that I don't need from lots of different things. How about if I send them over, you can throw them on the ground and then see if you can find a place for them. The inside of the transmission/final drive case looks like there'd be lots of room to put some extra thingees.😉
Sat, Sep 15, 2007 3:01 AM
Neil D
Send a private message to Neil D
Reply to 196200:
Hey TC,
196200
Theres no point in sending the extra bits over as TC prefers to leave a few bits out when hes rebuilding rather than adding bits on!!!!
Sat, Sep 15, 2007 5:21 AM
ol Grump
Reply to Neil D:
196200
Just think. .all the extra bits'n' pieces that are left over can be used to someday build a Catamatsu D6.7.8.9😮
Sat, Sep 15, 2007 5:28 AM
hardtail
Send a private message to hardtail
Reply to ol Grump:
Whatever poundage your earning on that job isn't enough, always amazed at your field repairs.😮
Sat, Sep 15, 2007 1:05 PM
Ron Gordon
Send a private message to Ron Gordon
Reply to hardtail:
It is nothing short of amazing how much you can get done outside in the weather,no matter what it happens to be like at the moment.I often wonder how much discipline it takes to be sure that all of your tools make it back into your storage area at the end of the day.I hold my own tools to be precious and occasionally one gets away.I will confess at my age that I might just have forgotten where I "stored" them as I have discovered them while looking for something else and tried to remember how they got there.I don't "loan" my tools to anybody but I will confess to buying extras of dubious quality that I wouldn't miss if they didn't come back and those are the ones that get loaned if I am hard pressed to do otherwise.Great pics!!!Ron G
Sat, Sep 15, 2007 7:15 PM
SJ
Send a private message to SJ
Reply to Ron Gordon:
Ron you living in Ct. you know what winters are the same as me here in NE Pa. & years ago at the dealer we had to go out in "0" weather & work on that cold iron & sure wasn,t any fun & the road servicemen do yet. We had some fuel oil heaters we,d fire up (salamanders) to help but you weren,t most the time near it to enjoy the heat. They now have cranes on the bigger service trucks they all have now which sure helps lifting big assemblies now where we had to rig up something to lift with or get the customer to bring a loader or whatever to lift things for us.It sure is a whole new world out there today for service men & can envy them.
Sat, Sep 15, 2007 7:40 PM
nicky lamb uk
Send a private message to nicky lamb uk
Reply to SJ:
on the subject of 68A's,what happens if you forgot to fit the keeper plate on the imput shaft of the transmission?.I noticed it missing whilst fitting winch propshaft.That was 90 machine hours ago.I don't suppose it can go anywhere and I don't fancy pulling the drive coupling one night.
Neil D,is your D9G one of A+A's old tractors? nice looking tractor.
Sat, Sep 15, 2007 11:36 PM
tctractors
Reply to nicky lamb uk:
Nicky I have never left off sutch an important item ???, sometimes I get left with a few O-rings that I store in my dustbin size pot of leftover O-rings, I have also been working on a few Cummins engines a Vee 12 and a Vee 16 (KTA30-67) both these engines have needed a good amount of work, the 12 cyl, needed a new set of pistons/liners, all the valves "48" sorting plus new cam bearings,this task is about half done as I get bored easily after 6 cylinders,the Vee16 is a fair old banger and I am using this engine to school a good lad on the workings of the CUMMINS, it's 50.25 ltrs so its a good sized item to pass on high H/power knowledge to a sharp chap, both these engines are outside in the open ,sadly the cold weather is starting in fast, if I can stick it for another 20 years that will do me at 72
tctractors,
ps, martyn ask Karl what car was in need of a tow behind the L/Rover
Sun, Sep 16, 2007 3:38 AM
| Kingaroy, Queensland
