Big Cats in a tunnel...
Showing 1 to 10 of 15 results
TimT
Send a private message to TimT
Last week we worked on a 47 car derailment in the St.Clair Tunnel between Sarnia Ont & Port Huron Michigan. It was one of the toughest jobs in years. Many heavy cars and a 200 ton DPU locomotive had to be dragged through the ballast stone and clear of the 6,000 foot tunnel. A clip and pics [video]https://www.dropbox.com/s/9tuz419n863z3z5/St%20Clair%20Tunnel%20Wreck%20edited%20clips%20com bined.wmv?dl=0[/video]
[attachment=54656]62235288_2312480929079687_3832015464108654592_o.jpg[/attachment]
[attachment=54657]65393760_2732680843426173_998772169120940032_n.jpg[/attachment]
[attachment=54658]65733385_2741971005830490_6852007914266165248_n.jpg[/attachment]
[attachment=54659]65821957_2743577869003137_2874845628117024768_n.jpg[/attachment]
[attachment=54660]65916411_2743579789002945_4872403577110265856_n.jpg[/attachment]
[attachment=54661]DSCF3976.jpg[/attachment]
[attachment=54662]DSCF4017.jpg[/attachment]
[attachment=54663]DSCF4065.jpg[/attachment]
[attachment=54664]DSCF4071.jpg[/attachment]
[attachment=54665]DSCF4075.jpg[/attachment]
Thu, Jul 11, 2019 11:57 PM
Hobo groh
Send a private message to Hobo groh
do you get hired then you haul the machines to the site? thanks :clap2:
Fri, Jul 12, 2019 1:33 AM
Reply to Hobo groh:
What was the cause of the derailment? Track maintenance??
Fri, Jul 12, 2019 1:45 AM
TimT
I have no idea. After a few dozen wrecks you don't care, just there to clear them up. The last thing it would be in that tunnel is poor rail... Its heavy rail, concrete ties in new condition and very well maintained. Could have been any number of things.
Fri, Jul 12, 2019 6:40 AM
TimT
Reply to Hobo groh:
Just like a wrecker outfit, but instead of cars and trucks, its trains. The railroads call, we go.
Fri, Jul 12, 2019 6:43 AM
Thank you received: 140
Reply to TimT:
Hi, Tim T.
Good stuff. Thanks for sharing. Pulling that loco out musta bin some job.
Fri, Jul 12, 2019 7:00 AM
Hobo groh
Hi, Tim T.
looks like a fun job.
Fri, Jul 12, 2019 10:52 AM
Reply to Hobo groh:
You have to assume that when a derailment occurs outside that the energy is dissipated by the cars going every which way. My impression is inside the tunnel, they expend that energy by smashing each other into wreckage? Looks like a lot of twisted iron to dig/yank out of there?
Fri, Jul 12, 2019 7:08 PM
jumbo
Send a private message to jumbo
Reply to drujinin:
Which end did you go in through, Canadian or US?
I'm not afraid of hard work; I can lay down beside it anytime and take a nap.
Fri, Jul 12, 2019 8:02 PM
TimT
Reply to jumbo:
We worked from the Sarnia side, and Yep with no place to go, some of those cars were mangled beyond recognition. It took 9 big cats and a track derrick to pull the locomotive out, we dragged it nearly 3,000 feet in balla. It had minimal damage and at four million bucks, they sure did not want to cut it up in the tunnel. One of the biggest wrecks for all around difficulty and size I have ever worked. It was a pure brute force job. We used cable as big as 3" and 150 ton shackles to get heavy enough rigging to hold together.Everything had to come out by straight pulling power.
Sat, Jul 13, 2019 8:05 PM
Reply to TimT:
Hi, Tim T.
Thanks for all the shared material. Great stuff.
I have worked in railway tunnels several times in the past. With heaps of diesel engines in there, often under full load, ventilation is quite the issue and being around 3,000 feet in would make it all the more so, especially with multiple trips and even more so for the people staying in there between pulls. Would it be a 'rude' question to ask how they coped with that?
Sat, Jul 13, 2019 8:18 PM
