The best guess that I have been able to come up with is that the series of numbers 6-11-28 and 11-23-29 and the dates that casting was machined. I have found number series like that on the back of some L/PL trani housings. Are both of the Cat machines San Leandro machines?
Ken
I would agree, Date of either the casting or machining
cts
Ken
the wide yellow is a PS it’s a late model for sure
the grey one I believe is a San Leandro based off the older parts that match up to BEST models. It does have the Large track roller springs tho.....
the best obviously is a San Leandro (I think that 1440 is it’s S/N).....that was welded on the block in the picture.
I was thinking that they were date of casting also, that was a guess, the 762 on the top of the grey one tho always confused me tho ......
if they are casting dates then the 762 would be? Any guess??
thanks,
shaun
The 1446 is cast in block, not welded, It is casting number S-1446. applys to tractors serial numbers S-3101 to10536 (1925 to 1930) and PS1 to 13285 (1925 to 1931)
The date of tractor creation and serial number assigned, could be between 1 and 3 months after the machining date stamped in case. This is based on comparing machining date and tractors with serial numbers.
