Best after market parts manufacture
Snonberry
Send a private message to Snonberry
Hi
I am after the best manufacturer for aftermarket parts for a d4 6u
I have a d4 6u serial number 6u 9726 and in oz
I have been to the local cat dealer and they can get all the parts most are ex USA but want an arm and a leg for them.
I have been looking at after market parts and are half the price.
I have been told to be carefull when buy aftermarket parts.
Just want to know what parts other people have used.
Dave
Tue, May 27, 2014 9:05 PM
Old 3T lover
In most cases, I would rather have a good used original CAT part than a new after market part if possible.
Wed, May 28, 2014 1:26 AM
Reply to Old 3T lover:
I don't believe there is a best "single source" for aftermarket parts.
General consensus seems to be approach major internal parts with caution. Not so critical on things like undercarriage or other external parts.
Wed, May 28, 2014 1:54 AM
Mike Meyer
Your options will be limited for aftermarket parts, what exactly are you looking for because from my experience you can't beat Cat prices on nuts, bolts, seals, and usually gaskets like head gaskets, aftermarket bearings you can buy cheaper from Tilly's but you may not get the same strength spec bearings as originally fitted so the few extra $$$ you pay for a Cat bearing are worth it in my opinion, that happened to me on gearbox bearings I fitted to my D4 7J and luckily we noticed it when assembling the tranny, the bearing Tilly's supplied for the transmission shaft was not a high load bearing as required.
There are a lot of old D4's around Oz, put up your location so people know where you are, there might be one being wrecked near you.
Regards
Mike
Wed, May 28, 2014 3:58 AM
catsteve
Send a private message to catsteve
Reply to Mike Meyer:
Regards
Mike
Florin (USA) sell genuine Cat and aftermarket for about half the CAT list price from memory. They are a good source for harder to find parts.
Wed, May 28, 2014 6:06 AM
Snonberry
Reply to catsteve:
I'm in Western Australia . The dozer has been sitting a round becaue the per combustion rusted out.
I have the motor out. Sump off head off. The water was in number 2 pot. Last night I got it to trun over had Diesel in the pots for about 2 weeks. Going to take out the pistons to night. The other thing I wanted to ask was has any one had to wield up the sump were the spring pack sits. It looks like it's being fix up at some time and may need doing again
Wed, May 28, 2014 12:27 PM
Stuss
Send a private message to Stuss
Reply to Snonberry:
I have just brought two D4 7U and one 6U suitable for wrecking so if you need second hand parts .
Stuss
Wed, May 28, 2014 2:04 PM
rax200
Reply to Stuss:
Stuss
Hi Dave
I have to agree with Mike, Cat is much cheaper on Nut, Bolts, Gaskets and misc parts. I have just finished rebuilding my gearbox and steering clutches on my 4G, (doing the final drive sprocket bearing/seals now). I found that Cat bearing is about 1/3 less than the best price at my local bearing shop could give me. What might seam expensive? It is not, in the long term as you get the right part for the right job and not some substitute.
Wed, May 28, 2014 3:42 PM
Mike Meyer
Reply to Stuss:
Stuss
[quote="Stuss"]I have just brought two D4 7U and one 6U suitable for wrecking so if you need second hand parts .
Stuss[/quote]
Crikey Steve, 3 new Cats in the yard, poor Helen must have trouble finding somewhere to park her car now, any of those girls have decent bottom rollers and tracks, I need 8 good bottom rollers and a set of tracks for my D4 2T when I get the time to tear into her.
Regards
Mike
Wed, May 28, 2014 6:03 PM
