Best 60 identification help required
Showing 1 to 10 of 16 results
David Parfitt
Send a private message to David Parfitt
I've been working on adding serial numbers to the page of Best photos on my website: http://www.steel-wheels.net/best.html However, I've run into some problems when it came to tractors I photographed at the Best Show on Tracks in 2008, as I neglected to note down any serial numbers for these at the time. Tom Madden has been a great help in identifying many of the tractors for me so far, but I'm hoping that the collective expertise of this forum might help me to pin down the identities of some of the others.
The photos below show the Best 60 tractors that I'm still lacking data. If anyone can help me out with the serial number of any of these tractors I would very much appreciate it. Or even if you can provide me with the owner's name (privately if you prefer), I might be able to find the serial no. from the BSOT attendee listing that was compiled after the show.
Thank you very much for your help in advance.
Best wishes
David
Thu, Nov 17, 2011 3:07 PM
Tom Madden_archive
David, top row left to right:
1. Joe Heidrick, Woodland
2. Jack Wallace, Woodland
3. Horsearound Ranch, Al. H. who recently died. This is an early Cat 60 I believe 2554 A. Sonora, CA
4. Joe Heidrick, Woodland
5. ??
Second row left to right:
1. Russell Turner, Woodland, CA
2. Traynham Ranches, Arbuckle, CA
3. Jack Alexander, Gilroy, CA
4. Sold at the auction, small crank shaft Best 60 chassis with a late Caterpillar 60 engine.
Fri, Nov 18, 2011 12:27 AM
7upuller
Reply to Tom Madden_archive:
5. ??
Tom,
You're slipping. How come you didn't know #5.LOL It's amazing how much knowledge of what and who you know.-glen
Fri, Nov 18, 2011 1:05 AM
David Parfitt
5. ??
Many thanks as always Tom! I'll compare these names with the listing and see what I can come up with.
One query though: does Russell Turner have two Best 60's? I've already identified his tractor 2363-A as the one in the pic below (from his name on the info sheet), but this one has a mesh in front of the radiator, whereas the one in my post above (second row, first pic) doesn't so not the same tractor.
All the best
David
[attachment=11252]Best60_BSOT08_5.jpg[/attachment]
Fri, Nov 18, 2011 1:14 AM
chriscokid
Reply to David Parfitt:
All the best
David
here are some names and numbers
ACMOC ISSUE 82 pg. 20-26
Fri, Nov 18, 2011 2:20 AM
David Parfitt
Reply to chriscokid:
Thanks Erik, that's the listing I have too. Do you think you can identify any of the tractors in my pics from the photos that Deas P sent you? I photographed the lineup early in the morning, but it's possible that some of the tractors had information sheets hung on them later in the day, or maybe he took some pics of the serial plates?
All the best
David
Fri, Nov 18, 2011 2:35 AM
Tom Madden_archive
David:
If that is not RT's then it belongs to Traynham Ranches. Interesting that both have the wrong carbs with Cat 60 Ensign as oposed to the Stromburg that they should have.
T
Fri, Nov 18, 2011 2:37 AM
David Parfitt
David:
T
Thanks Tom. Does that mean that Traynham Ranches own the tractors in the first and second photos in the bottom row then, or is the tractor in the second photo someone else's?
David
Fri, Nov 18, 2011 4:05 AM
chriscokid
David
David,
I will check the pics and let you know the results.
I sent you several emails with pics and info
Fri, Nov 18, 2011 4:10 AM
David Parfitt
David,
Thanks Erik. We need to compare notes soon on the serial number listings, as I've been overhauling mine recently and might have some new numbers for you to add to your pages?
All the best
David 👋
Fri, Nov 18, 2011 4:41 AM
4tcompost
Send a private message to 4tcompost
All the best
David 👋
first 60 in second row is traynham ranches with ensign carb. 60 in next photo has stromberg carb tom
Fri, Nov 18, 2011 11:05 AM
| Kingaroy, Queensland
