Berco rails
Berco rails
Showing 1 to 10 of 12 results
Jimmy977
Send a private message to Jimmy977
Hello folks.  Looking for information on berco cr243 links on a D4 7u.  Link height is ok. But has been run with a loose shoe. Wondering is loose bolts holes in links fixable,  or replace link. Also Wondering if anyone knows if single links would be available.  This machine could also use shoes replaced. Bushings still very good also.
Tue, Apr 25, 2023 11:23 PM
D4Jim
Thank you received: 12
Replacing a link is quite a job even if you have the correct equipment. Is the link worn enough to affect the integrity of the chain? Are you going to use the machine daily or just a few hours a year? "Loose" can be subjective so can you get a photo of the rail? Might be possible to ream it out and install a bushing to save the hassle of changing the link if the link is otherwise OK. .
On the other side I don't know of many Berco parts left anywhere unless by chance you could find on laying around somewhere.
Cats Forever
Wed, Apr 26, 2023 7:18 AM
Thank you received: 33
Reply to D4Jim:
another way could be to fill the holes with bronze and re drill to size. is it only one hole that ovalled or have they all ovalled on that link?
it is possible to rebuild grousers too by welding a piece of medium tensile bar to each grouser using low hydrogen rods.
Wed, Apr 26, 2023 12:40 PM
PhilC
Reply to trainzkid88:
Grouser bar is the correct profile and steel alloy for building up grousers.
Before looking at replacing links I would cut the old bolts out, grind any burrs flat and then put new bolts in and torque them up to the correct tension. You would be surprised how big an oversized hole a correctly torqued bolt can hide. Bolts in track plates and links are not a machined fit so they have a small amount of clearance even when new. Even better would be to fit a replacement shoe on it with new torqued up bolts. I have done this several times with good results provided all burrs are removed and the holes in the plate are not worn dish shaped then they usually stay tight indefinitely..
Wed, Apr 26, 2023 6:47 PM
Reply to PhilC:
also consider some high strength epoxy or lock tite on the bolts
Wed, Apr 26, 2023 9:58 PM
Jimmy977
Reply to PhilC:
Thanks for replies. This looseness is the track shoe bolts. I have not removed loose shoe yet. I like the idea of oversize bolts, that definitely may fix it. The shoe plates are thin, grousers have been built up in past with bar. This is a case of old shoes being reused on new rails I think. Shoes are just wore out. Couple are cracked and bent. The current shoes are 18". I'm wondering if new shoes are available. I believe these are 1/2" in bolts.
Wed, Apr 26, 2023 10:06 PM
Glum
Reply to Jimmy977:
What are your intentions for the machine?
If it's just one or two grousers and you intend using the machine with the current undercarriage for a year or two still, then I'd just weld the grouser to the link for the time being. Nothing you can't cut loose at a later stage.
Thu, Apr 27, 2023 12:44 AM
Reply to Glum:
fit new bolts and see what it feels like the bolt are probably worn a bit too metal on metal rubbing wears both parts. did searc for grouser plates a couple of yrs back and the cat parts system did have a listing for the part numbers still. so new grousers may still be available. would be a bloody expensive exercise though. one thing about worn grousers they wont grip aswell if the going gets tough more likely to slip so less likely to strain something in the driveline and break a part that isnt available anymore. you can rebuild anything if you have the ability or the money to spend.
Thu, Apr 27, 2023 5:30 PM
Jimmy977
I will look for good used shoes or aftermarket new if available. Either way I will use new bolts. I do know of a set of used but brand new looking shoes. 2 problems with these shoes is they are 13" shoes. Also I suspect it would be 31 shoes per side, its an ag tractor ,and my machine currently is 32 per side. I would prefer the 18", but this used set is very low mileage.
Fri, Apr 28, 2023 3:31 AM
Reply to Jimmy977:
a good used set may just be the right choice but something to remeber are you going to earn money with it, or just do a little work around your place or demonstrate it at a event or is it purely a display machine. if its just a display machine and only needs to move itself on and off transport then replace the loose bolts and leave it alone. no need to create work for yourself and the resulting hole in the wallet.
Fri, Apr 28, 2023 10:01 AM
Jimmy977
I would make a little money with it. I occasionally sell firewood off my property. But mainly for property maintenance. Road grading, clearing downed trees. Also have a sawmill for personal use, so skidding logs.
Fri, Apr 28, 2023 8:54 PM
