Bent push rod ?
Bent push rod ?
951c
Send a private message to 951c
951c here again with ? about 3304,
Pulled or the valve cover today and found what I think was knocking . For refresher I ran the machine embarassing low on oil,now I know why I had no throttle . Anyway when I filled the oil back in the crankcase I fired her up and thats when the bad knock started. so did something colasps? Whats the next step ?
Mon, Nov 12, 2012 9:17 AM
straycat.inc
Send a private message to straycat.inc
Cut your oil filter open and check for metal. Did you shut it off, or did it quit on it's own before you added oil? How much oil did you have to add? Looking forward to more info.
Mon, Nov 12, 2012 10:32 AM
951c
Reply to straycat.inc:
It quit on its own,not knocking ,then added oil and and it started and I shut it it off! It was'nt reading on the stick. Now I'AM thinking rod bearings and hoping the scoring is'nt that bad. I'am really embarassed about the oil because ,until now,I had a very ,very dillingent lubercation habit on all my stuff. The other thing that stinks is that the machine is my land 200 miles from me in NY.
Mon, Nov 12, 2012 5:01 PM
Thank you received: 30
Reply to 951c:
Hi 951c,
sorry to hear of your dilemma.
Bent pushrod is most likely due to a failed conrod bigend bearing. The piston can then travel higher in the bore and contact an open valve on the valve overlap cycle.
It likely did not knock previously due to the steel back liners of the bearing shells having rotated in the rod and overlaped oneanother, thereby taking up the bearing clearance.
They likely are now rotated to on the top (12 O'clock position) in the rod bore and can then push the piston higher in the bore to hit the cylinderhead and an open valve.
As was said above, check your filter element for tell-tale signs of bearing metal.
Hope damage is minor.
Tue, Nov 13, 2012 9:04 AM
951c
Reply to edb:
Hi 951c,
Thanks Guys !!!!
Tue, Nov 13, 2012 10:41 AM
