belly pan?
belly pan?
deckert d69u
Send a private message to deckert d69u
Will a belly pan keep the brush and small trees from coming up into the trans? or is there something else that would help that? I only worked for 2 hours and have 2 inch sticks coming up to the floor boards..
thanks for any input.
Les
d6 9u dozer
Russel hiway patrol no 1
Wabco 555 grader
superA farmall F 12,F 20 and various pcs. of rusty red tractors
Thu, Apr 26, 2012 11:02 AM
bullcrk,6
Send a private message to bullcrk,6
the belly pan will protect the engine area from debris there is also a transmission guard that bolts on behind
the belly pan and protects the transmission area from sticks and rocks, used together not much will get threw
Thu, Apr 26, 2012 12:06 PM
Reply to bullcrk,6:
The "U" model belly pan is a must for dozer work.
Also that transmission case isn't as stout as we'd like to believe with plenty of them getting cracked/busted.
It is a two piece affair as shown in the picture, going back to attachment at the draw bar mounting bracket. Not much fun when you need access though. The tow hook is a nice addition.
Thu, Apr 26, 2012 11:14 PM
Woody
Send a private message to Woody
Location: 5205 Thousand Springs Drive, Ammon Idaho 83406
I have both the front and rear belly pan guards for a 9U D6, less the bolts or hardware to mount. Let me know if your interested.
Thanks,
Woody
Fri, Apr 27, 2012 4:29 AM
