BeGe pump
BeGe pump
ErnieinTucson
Send a private message to ErnieinTucson
Hi all
Working on a BeGe 3 valve stack. I am having trouble with the stack leaking! Any thoughts?
Ernieintucson
Sat, Aug 8, 2015 6:19 AM
Is that internal or external leakage?
If it's internal leakage these old BeGe valves are often worn out with excessive spool/land clearances. If that's the case repair is expensive and unless your determined that's usually the end of the line.
Sat, Aug 8, 2015 7:25 AM
Casey Root
If the leak is around the spool, we've had them rebuilt at Rutter Armey in Fresno. Might try them for a quote. They made a diet of repairing them along with a lot of other machine work.
Good Luck.
http://rutterarmey.com/contact.html
Sat, Aug 8, 2015 3:31 PM
ErnieinTucson
Reply to Casey Root:
Good Luck.
Thanks guys!
The leaks are in the stack to out side! I have some differant gaskets and differant sealer with out any luck.
Ernieintucson
Sun, Aug 9, 2015 4:13 AM
Reply to ErnieinTucson:
Thanks guys!
Ernieintucson
Check the flanges for warpage.
Sun, Aug 9, 2015 8:01 AM
