BeGe model 1000
BeGe model 1000
Soapy
Send a private message to Soapy
The four bolt flange that connects the valve body to the pump, is seeping, and I would like to know what kind of material should be used for resealing the flange.
Sat, Mar 1, 2014 7:04 AM
Thank you received: 62
Most gaskets in Bege stuff I have been in had paper gasket from the heavy stock,have one valve that is all o rings.Associated Tractor(they are listed in parts sticky)has the gaskets and o rings for the common stuff.They are not cheap but some times considering the alternatives they are not so bad. Never found a source for 1/4 in o rings with 1 in ID for us on the 650,850 control valves so I payed there price,and saved a lot of oil.
Ray
Mon, Mar 3, 2014 12:02 PM
Soapy
Reply to Ray54:
Ray
[quote="Ray54"]Most gaskets in Bege stuff I have been in had paper gasket from the heavy stock,have one valve that is all o rings.Associated Tractor(they are listed in parts sticky)has the gaskets and o rings for the common stuff.They are not cheap but some times considering the alternatives they are not so bad. Never found a source for 1/4 in o rings with 1 in ID for us on the 650,850 control valves so I payed there price,and saved a lot of oil.
Ray[/quote]
Thanks for the info Ray. Now if I can only find time to tear it apart.
Have you checked California Industrial Rubber for O rings? They have a huge selection.
Thu, Mar 6, 2014 11:38 AM
