Bee Gee hydraulic pumps
naylorbros
What is the maximum pressure that a Bee Gee was set at at the factory?
Ken
Wed, Jun 27, 2012 2:53 AM
Thank you received: 19
What model system are you referring to? Most the old horizontal and vertical stacked valve units were 1000 psi max.
Pumps alone, some were rated for 2000 psi with 1500 psi recommended operating pressures. I believe the very late units could handle 2500 psi.
Wed, Jun 27, 2012 3:27 AM
