Bearings, 7B7349 and 7B7350 I.D. help
hotrodwelder1
Send a private message to hotrodwelder1
I found some engine bearings, 7B7349 and 7B7350. I believe they are con rod bearings and are the updated part number for the 2F2343? Can anyone verify this please? These have a bronze backing with an aluminum or babbet bearing surface.
Thanks, Chris
Fri, Feb 9, 2018 10:14 AM
A google search hits one website that crosses them as you indicate. I believe they are connecting rod bearings for the EARLY D6600 and other engines in the same series. Should fit a 3.250" crankshaft journal.
There is a thread from 2007 on ACMOC that comes up on the search where beaver flats was looking for some.
Fri, Feb 9, 2018 8:54 PM
hotrodwelder1
Thanks ccjersey, i found that google search and thread, but i wanted to verify. Sometimes google doesnt have the correct info..
Mon, Feb 12, 2018 7:23 AM
| Kingaroy, Queensland
