Bearing Interchange
Bearing Interchange
Showing 1 to 10 of 14 results
Apparently I am not smart enough and have exhausted my resources, not to mention patience!
Can someone cross reference the "Hyatt 7788" bearing that was the pilot bearing for a CAT TEN?
I need to order a replacement.
Thanks!
Tue, Nov 6, 2012 10:33 PM
Thank you received: 46
No such number on my interchange list. Do you have the Cat #?
Wed, Nov 7, 2012 12:03 AM
chriscokid
maybe this will help? http://www.ytmag.com/cgi-bin/viewit.cgi?bd=implment&th=98905%3E
Timken interchange http://www.timken.com/pl-pl/products/Documents/Timken_Bearing_Cross_Reference_Guide.pdf
Wed, Nov 7, 2012 12:13 AM
No, I just yanked out the bearings on 2 separate flywheels and these Hyatt's popped out.
Didn't think to go through the CAT book to look from that direction.
I pulled this out of ytmag, "The correct numbers are--Bearing = 9040k and the race is 9039k"
Only difference seems to be my race isn't split.
Wed, Nov 7, 2012 1:30 AM
catrjw
Send a private message to catrjw
Reply to drujinin:
You can get the bearing race from McMaster Carr online sold as drill bushings. I used these on my Ten and Fifteen. Just measure the old one. The bearings I orderd using the Hyatt number from Applied Technoligies in PGH.Hope this helps,[email protected]
Wed, Nov 7, 2012 10:23 PM
Reply to catrjw:
Are the bearings the same for the 10 & 15? I have the two part bearing numbers for the 15 as listed by Hyatt.
Wed, Nov 7, 2012 10:32 PM
Yes, the FIFTEEN would be the same part number.
Thu, Nov 8, 2012 1:07 AM
Reply to drujinin:
From my 1942 New Departure and Hyatt bearings Tractor Catalog #A-205
the clutch pilot is listed as a #00531 roller assy and #31262 race and that's for a 1933-35 Model 15
Couldn't find anything on interchange for those numbers either.
Could still chase it by the Cat part # if someone can come up with it.
Thu, Nov 8, 2012 10:19 AM
josh
Thank you received: 13
Ten clutch pilot bearing, 1B3755, is one each of 1B3756 and 1B3757. I can cross the 1B3756 to a Hyatt 95416 and a Rollway 140516, no luck on the 1B3757. 1B3756 was also used on the steering assy. on some U series D4 etc. (8 per tractor), and may be available.
Thu, Nov 8, 2012 11:25 AM
Mike Walsh
Reply to josh:
The 1B3756 was available two years ago. I replaced a couple of them. General Gear has a cross reference for the 1B3757.
http://www.tpaktopc.net/cgi-bin/Cat_Part/Cat_Brg.cgi?findPartNum=1B3757
Thu, Nov 8, 2012 12:30 PM
catrjw
Reply to Mike Walsh:
The PV 15 is not the same
Thu, Nov 8, 2012 8:42 PM
